Question about Xerox XA7-172i 17" LCD Monitor
The computer turns on fine but as soon as the windows display comes up it flashes analogue rgb and goes black
  • 73 Answers
Start windows in safe mode and check resolution settings set it to 640X480
Posted on Sep 23, 2009
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Monitor fine with 1 PC, no RGB input after windows load on other?
Lower the resolution on the computer to 800 x 600 and then hook up that monitor see if it at least accepts that and doesn't go black. You may have to go into safe mode to do it plus then go back into regular mode.
May 07, 2010 | HP mx705 17" CRT Monitor
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Recording DVB on this DVD recorder?
Have sorted this problem now, I purchased a SCART DVB TV Unit from Freecom, this did not work at first connection, but I then realised that it had to work as RGB into the SCART plug on the DVD, once I set the unit to RGB, all was fine.
I can now record Freeview on my DVD fine.
I do however have one prblem which this will not overcome, that is the addition of yet another remote control !!!
Byeeeeeee..
Nov 30, 2007 | Pioneer DVR-220 DVD Recorder
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Xerox XA7-172i 17" LCD Monitor Logo
124 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
steve morris
steve morris
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
