Question about Freezers
Can an upright freezer be used as a beer fridge?
I was wondering if an upright freezer turned as low as possible could be used as a beverage fridge?
    Champion:
  • 249 Answers
If it freeze's water it won't do,test first!
Posted on Dec 18, 2007
Danby upright freezer plugged in a few hours ago, but coils on back are hot
If you are talking about the black condenser coli on the back of the fridge it is hot because the refrigerant is pulling all of the heat out of the fridge and trying to deposit it outside of the box. This is called hot box pull down. When the temperature inside the fridge comes down and you have product in it the coil on the back will become much cooler during operation. So if you are wondering it is nothing to be worried about, perfectly normal.
Aug 29, 2014 | Danby 10.4 cu. ft. / 294 liter Upright...
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
I don't have a problem... just a question. I purchased the kenmore 7.5 cu feet freezer for our garage. I was wondering in the future if I turn it down to the 1 on the dial (outside) can I use it...
Hello, Thank You for using FixYa. I will be helping you today. No the unit will not work as a fridge.
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Inside fan runs but freezer is hot
On this video, Delfield refrigerator with freon issue (restricted system)
May 06, 2011 | Delfield Upright Freezer 403
HAVING PROBLEM WITH COMPRESSER TO HOT
If the condesnser coils are clean and condenser fan blde as well and refrigerants not low or(non condensibles) air in the system (high head pressure) than the superheat to the compressor should be ok, not more than 20 deg super heat at the compressor generally, if thats not it the thermal overloads bad or compressors low on oil or tired, take amp deaw and see pressures to know for sure, check super heat and subcooling too.
Jan 12, 2011 | Beverage-Air 23.1 cu. ft. / 654 liter...
I want to use my freezer for beer. Can I raise the temperature by changing the thermostat? Any other suggestions besides using a fridge?
Not sure of your make/model. If its a standalone freezer you could exchange the termostat with a Fridge, or you could jury rig a seperate line voltage thermostat with probe in the compartment, which you would plug the fridge into and would override the internal thermostat (internal thermostat would always be calling for cooling because the line voltage thermostat would be set higher--any time the temp increased above the set point on the line voltage tstat the relay would close and the freezer would run). An anti freeze alarm coupled to a simple relay or contactor would work for this purpose... depending on how handy you are I could explain all the necessary components...
Oct 11, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
I want to just keep cokes,water,beer etc. in my small upright frigidaire freezer. is there a way to just make it cold enough not to freez the drinks.
Go to Home Depot find you a timer they start at $10.00, you know turn lights off/on when your not home. . They have an digital one for about $16.00 Set it up, ck your times, run it then shut it off for a while keep adjusting till you can keep the temp you want.
Apr 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fridge and freezer both freezing
If your control is not turned up too high you likely have an insensitive one. In this case it needs to be replaced with a new one, not too serious.
Dec 18, 2008 | Kenmore Freezer 20.6 cu. ft. Manual...
Freezer Not Cooling
Sounds like the low pressure cutout switch is stopping your compressor running, especially if the "5 seconds" you mention are exactly the same length each time. Not enough refrigerant would be the usual cause, but the reason for the refrigerant loss is harder to tie down - possibly a seal or a loose valve seat or even a pinhole in a copper tube. Best solution now would be to get a refrigerator mechanic to top it up and check for leaks - get a quote first to check - 'fridge gas is getting costly. Other possible solution is that the low pressure switch itself is faulty, relatively inexpensive to replace (but unfortunately you will need at least a partial gas recharge on most types of system after) - your fridge gas guy will be able to check very easily if there is adequate gas in the system, and should check this low pressure switch if there is not. Usually this is fixable many times, just check the cost first. Hope this helps :)
Mar 07, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
94 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
