Question about Epson Perfection 4490 Film / Flatbed Scanner
Epson 4490 Photo - multiple PDF pages
I can't scan multible PDF images and put them into one document, even though the instruction manual says this is possible. Epson support has been no help.
Joe C
  • thptrek Jan 15, 2008
    I have same problem. Reinstalled software with no results. It only lets you scan one page at a time and not combine the pages into one document.
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Posted on Apr 13, 2009
  • Epson Master
  • 1,879 Answers
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Posted on Jan 26, 2008
    Problem Solver:
  • 12 Answers
I just wanted to ask...
are you using windows xp?
well, if you do...
pls try the ff.
The first thing we need to do is remove any files that have been installed and start with a fresh installation.
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on CHANGE/REMOVE.
7) Restart your computer.
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
1) Double Click on the Epson1****.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
4) Connect the USB cable. Windows will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use.
and then try the steps provided by ohms
goodluck!!!
Posted on May 13, 2008
Thanks ohms but the problem is that your item 6 is not coming up. It is like it goes straight to done and does not ask the ADD PAGE.
Scanned document is 8.5 x 14 even though setting says 8.5 x 11
You probably have the PDF programme page size settings incorrectly set to the larger size = why only able to print some of the length. As a solution, use a photo programme (Photoshop, Elements or the excellent FREE Faststone Image Viewer to resize the image so it will then print on your paper but so doing will reduce, slightly, the width to suit the revised shorter length to preserve the proportions/balance between length and width.
Apr 01, 2014 | Epson WorkForce WF-2530
My Epson CX3810 all-in-one priner does not allow me to scan mulitiple document into one file. Each page is scanned as a seperate document.
The documentation is here: http://files.support.epson.com/htmldocs/cx38__/cx38__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
You can scan multiple pages of a document on the document table and save them as one PDF file on your computer. Epson Scan displays an editing page so you can view the pages as you scan them and reorder, rotate, or delete them as necessary.
Select PDF as the file type setting.
When prompted "scanning complete.  Do you want to continue"  Click "add page"
Feb 28, 2011 | Epson Stylus CX3810 All-In-One InkJet...
Am unable to use the feeder tray - it keeps saying paper jam. There is no jam -- something seems to be blocking the mobility of the paper. I have it on "office" use and the regular scan works one...
Click on the link below and download the User guide which will help you solve the paper jam problem.
User Manual
The above link has complete information for your Epson Scanner.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 13, 2010 | Epson Perfection 4490 Office Flatbed...
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson problem
Here is the download page
http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
Aug 22, 2009 | Epson CX8400 All-In-One InkJet Printer
Escndv.exe problem connected with Epson scanner 4490 Photo
http://www.howtomendit.com/answers.php?id=64090
Go here: C:\Document
s and Settings\[username]\Application Data\EPSON\ESCNDV\ES0058
and delete any image files in that folder. The last folder might have a different number depending on your scanner. It should start working again.
If you can't see that folder - click on My Computer - in the menu click on Tools and select 'Folder options..." Click on tab 'View' and select 'Show hidden files and folders'
You should now be able to see 'Application Data' in Docs and Settings...
May 30, 2009 | Epson Perfection 4490 Photo Scanner...
Can't scan slides on Epson 4490
Please make sure that the option cable on the back of the scanner is seated properly.
You may need to trash and re-install the drivers.
To get the most recent driver compatible with your operating system, please log on to epson.com and go to the drivers and support page.
Apr 28, 2009 | Epson Perfection 4490 Photo Scanner...
I have just bought an Epson 4490 flatbed scanner and want an owner user manual as this is a new machine and there was no real instructions on how to operate the Epson 4490
Here's the Epson Support page for your scanner. Just click on the Manuals and Documentation link for all the available information about the 4490:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
It's possible that the Tutorials and the FAQs will be more useful to you..
Fixya!
Chris (ziraffa)
Jan 11, 2009 | Epson Perfection 4490 Office Flatbed...
Epson Perfection 4490 Film / Flatbed Scanner Logo
2,503 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
