IDE slave drive disappeared from My Computer.
I have an old (about 7 years old) IDE 40 GB hard drive that I use as a second data drive in my desktop PC. It’s worked flawlessly for years. For background, I’m working in Windows XP SP2 on a Dell 2400. I have the drive set in the “slave” mode via the jumper pins. When I originally installed the drive, my PC recognized it right away, automatically assigned it a drive letter, and life has been fine since.
Until the other day, when the drive suddenly disappeared – when I click on “My Computer,” only my main “C” drive shows up under Hard Disk Drives. It used to show a “C” and a “J” drives.
However, when I go into Devise Manager and look under Disk Drives, BOTH hard drives are there, with their unique ID numbers. So to some extent, my computer is recognizing this slave drive. However, there’s no way to get to the data on it.
I hear no obviously clicking or noise from the drive. The drive appears to be getting power since it’s warm (not hot) to the touch when the PC is on, and I feel a slight vibration when I touch the drive when the computer is on.
A few things I already checked:
* I changed the power cable and the ribbon cable. No help.
* I installed this slave drive in another similar desktop that I own. Interestingly, Windows XP automatically detected the new hardware and installed it. However, like on the original PC, the drive is visible in Devise Manager, but does not appear in My Computer. (No drive letter was assigned.)
* As a double check, I took the slave drive from this other computer and installed it in the original PC. It recognized the slave drive right away, assigning it the drive letter “J” in My Computer and allowing full access.
So, it appears that I ruled out any motherboard problems, cable failures, or Windows problems.
I would like to be able to recover the data on this slave drive. Does anyone have any suggestions on what to do? Is there any recovery software that might work? Or, does this sound like a mechanical issue with the drive?
  • 3 more comments
  • markgross615 Sep 23, 2009
    The drive does not have an operating system on it, so would it still work as the "master?" Also, I'm not a full-fledged tech guy, so help me. What's "the second IDE channel?" Also, I know how to access BIOS, but what do you mean by "identify it in BIOS." Thanks.
    As I mentioned, the drive does not work on another computer. Would connecting the drive w/a USB adapter bypass the controller?
    Sorry if I'm not making myself clear. The 'bad' slave drive cannot be read in either computer -- not drive letter is assigned in either one. However, I have another drive that I set up a a slave, and BOTH computers recognize that drive and BOTH computers assign drive letters to that slave drive. If I set up the 'bad' slave drive as a 'master' using the jumpers, I would need to load Windows onto it, and I don't know how I could do that if I can't access it? Help!
  • 73 Answers
You might try to set this drive as master and connect it on the second IDE chanel. Identify it in Bios than boot XP.
Posted on Sep 23, 2009
  • 591 Answers
Sounds like the IDE controller has decided to misbehave, more than a drive issue. If the drive works in other computers I suggest you put the drive there, restore your data and work on the IDE problem.
  • Jaye Ellen Burke
    Jaye Ellen Burke Sep 23, 2009
    "... As a double check, I took the slave drive from this other computer and installed it in the original PC. It recognized the slave drive right away, assigning it the drive letter “J” in My Computer and allowing full access ... "
    While the drive is in this computer, can you copy needed information from the J: drive? The other computer, the one that does NOT recognize the drive to the point of assigning a Drive Letter is of interest to me. This computer is the one that I suspect the IDE Controller, usually built in to the Mother Board. This controller allows the user to access more than one Hard Drive, IDE type
    of drive. If you are capable of setting jumpers for Master Drive, can you load it with the OS files?
  • Jaye Ellen Burke
    Indeed I had misread your post. That's why I re-posted what I found. This "defective" drive, the one that can't be defined in either computer, may well be defective. If this is the case unfortunately the data is probably lost. Just FYI, though, older computers used the "IDE" or Integrated Drive Electronics hard drives. The IDE controllers were typically built in to the Mother Board; there would be two IDE connectors on the Mother Board, and each one has a Master and Slave drive possibility, leaving it possible to have 4 separate Hard Drives on any given system. IDE 1 Master would be the Boot Device, or C: drive. In your case though, the drive is not being recognized by the system (No drive letter) and therefore you're out of luck as far as data retrieval. You might contact one of those "Data Retreival" companies, and MAYBE they'll have some luck, but it's way past what I am capable of doing. Sorry.
Cant find the slave drive on boot
Master/Slave configuration I am assuming you have IDE hard drive and not SATA. SATA is a small cable IDE is a wide 40 wire flat cable. You must install the jumper on both drives as master and slave. On the old WD HDD master has jumpers between 5 and 6 and slave jumper between 3 and 4. Default is jumper between 1 and 2 which is cable select which you use for a single drive.
Nov 09, 2013 | Dell Inspiron 531s Desktop Computer
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
Dell Dimension 8400 running xp has died. Can I put the hard drive into a spare slot in a Windows 7 PC to get the data off the XP HD?
Two Options:1. Yes you can as long as your Windows 7 PC has the correct connection for your hard drive. Most likely you need an IDE connection. If you have an IDE hard drive and the Windows 7 PC has an IDE connection, then you will need to make sure to "slave" the hard drive by moving the jumper on the hard drive to slave mode.
2. If your Windows 7 pc doesn't have an IDE connection, the purchase a USB to IDE cable adapter:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770
This way you can plug your hard drive into any computer through USB.
Best regards,AbdielComputer repair plantation
Oct 27, 2011 | Dell Dimension 8400 PC Desktop
I would like to use my old 40 gb Western Digital Harddrive for a secondary data drive on my Desktop computer. When I hooked them both up and powered up the computer wouldn't boot, I assumed it was because...
http://www.lyberty.com/tech/hard_drives/WD_Caviar_WD400BB_specs/index.html
Above is the link to set the jumper on the 40GB to Slave.
Also, before it boots, try to get into the BIOS setting and make sure your compter can see both drives. If not, double check jumper settings for both drives. Turn off compter and change settings.
When computer can see both drives in BIOS, save it and let the compter continue to boot.
Hope this helps.
Jan 04, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
How to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
Adding old hard disk. 20 GB Quantum Fireball Ict, in Dell 9200 PC
if it's old it's probably IDE also known as PATA. it looks like a wide ribbon. There should be a header on the motherboard that looks exactly like the plug on the back of the hard drive. It will be labeled IDE1 probably if you have it. Old motherboards used to have 2 IDE headers, modern ones have one or none. The ribbon will have three plugs--one for the mobo, and then two spaced closer together for the master and the slave. You need to hook it to the appropriate plug (master if it's the only device on the ribbon) and make sure the jumpers on the HD are set properly to make it self-identify as the master. Good luck!
Nov 09, 2009 | Dell Dimension 9200 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
