Question about Fellowes 2200 Cross-Cut Shredder
Will go in reverse but not forward. is the paper sensor bad?
    President:
  • 3,085 Answers
Blow some canned air down into the feed slot to clean the sensor.
Posted on Sep 24, 2009
My Staples shredder will work in reverse just fine but it will not move forward, rendering it unable to shred anything.
They do this when they get dirty. There is a sensor that tells when it is full, the sensor gets paper dust on it and wont work in forward.
You need to clean it real well. If that does not help then the issue is something else like sensor failure.
Nov 21, 2016 | Staples Office Equipment & Supplies
Only goes in reverse when paper is inserted
Shredders have three settings
Manual forward
Manual reverse
Automatic
Better shredders also have sensors that turn on when paper is inserted. It sounds as if your is in reverse and auto start.
Oct 22, 2015 | Office Equipment & Supplies
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
Our Olympia paper shredder forward switch does not work but the reverse does.
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck..
Apr 15, 2011 | Olympia Office Equipment & Supplies
Doesn't work going forward only in reverse
sounds like you have a sensor problem. is it automatic reversing on jamb? if so sensor is defective, or there is a bind causing sensor to reverse only, a bent shaft could cause that
Apr 04, 2010 | Aurora Global AS501X-MS Shredder
Aurora Papaer Shredder circuit board problem?
It just sounds like a paper dust problem.
use canned air to completely clean all sensore.
Oct 23, 2009 | Office Equipment & Supplies
Model 12x royal paper shreddewill run in reversre but not forward
move the control button on top of the shredder to the oppoiste direction.
Nov 28, 2008 | Royal CIA 12X Shredder
Only runs in reverse
This is an issue with the paper feed sensor usually located in the center of the paper feed slot. If it is mechanical you need to jiggle switch in and out to free possible interference behind switch (piece of paper or debris) if it is an electronic sensor you more than likely have a bad sensor or pc board. You will need to contact manufacturer for any further assistance.
Mar 16, 2008 | Tech Solution TS-4500 Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
Fellowes 2200 Cross-Cut Shredder Logo
52 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
