Question about Symbol MC9090 Mobile Computer Portable Terminal
Change the backup battery in MC9060 - Symbol MC9090 Mobile Computer Portable Terminal
    Scholar:
  • 38 Answers
Hello mis1539. I think I can help you here. First: are you sure the backup battery is defunct? Bear in mind that the backup battery takes about 15 hours to fully charge and will discharge if the main battery or power source is disconnected or goes completely dead for anywhere from 30 minutes to a few hours. If the backup battery discharges, the process starts all over and the backup battery will need to be charged for 15 hours again. If you think the backup battery may have discharged at some point, it could be that it never full re-charged so it will discharge and lose your settings (cache/flash memory) almost instantly. It is worth mentioning that about 95% of my clients that have this problem have fixed it by simply making sure that the unit is in it's cradle, with the battery in and charging overnight to fully recharge the backup. Again, I really would implore you to give this a shot before resorting to cracking open the unit and getting to the backup battery (which is no fun task, I assure you). If this doesn't work for you, please let me know and I can help you further. I hope this solves your problem. Good luck!
Posted on Jan 06, 2010
  • dlucre Jan 06, 2011
    This task isn't too difficult if you have some basic tinkering skills. There are 2 screws in the battery compartment, and two at the back of the device at the top. Undo all 4, and gently but firmly slide the back (handle and all) towards the top of the device. Be very careful, however, as there are 3 small wires connecting to the back of the device to the handle assembly. So, you'll need to unplug these once the back pops open, to seperate the two.
    The backup battery is in the handle. You'll need to undo the screw holding it in, and simply pull the battery and rubber protective shielding out. Find a replacement, and reverse the steps above.
3 Suggested Answers
  • 65 Answers
SOURCE: how to install the backup battery for a Symbol
Well, you have to disasamble the unit first, it could be little tricky. Please contact me so I can get you more detail depending on your skill level. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Posted on Oct 20, 2009
SOURCE: Hi there, we've got a Symbol
on top of it there is black cover.
the shape of the MC9060 backup battery is as below
http://www.repairhppda.com/backup-battery-for-motorola-symbol-mc9000-mc9090-series-p-3629.html
Posted on Nov 05, 2010
Mc9060 loosing wireless profile after a cold boot or removing the battery then i have to reconfigure it everytime
This is a very common problem with this scanner, especially if its running Windows CE rather than Pocket PC or Windows Mobile.
Every time the terminal cold boots (has been left a significant time without the main battery and backup battery is depleted) it will rebuild any configurations from reg files saved within the Application folder on the device.
To save the wireless settings the profile (and options for peace of mind) need to be save/exported. This is done by hitting the wireless icon located in eth taskbar on the right hand side, from the menu select options. This pops up a box which contains a drop down box, from this select "export" then you can export profiles and options. Each time you will be prompted to save, use default and the relevant reg file will be saved to the Application folder and hence the settings will now persist through an old boot.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 18, 2012 | Symbol MC9060-G
Mc9060 no sound: in setting i set it to the high volume setting - enter - then check it is back to the lowest setting- not holding change in settings
you need to connect the handheld to your PC and then use software to change settings for the device. There is no other way for the settings to persist a cold boot.
Mar 17, 2011 | Symbol MC9060 Barcode Scanner
Hi there, we've got a Symbol MC9060 with defective Backup-Batteries. I've cold bootet the device and it has been loading on the craddle for days. Even after this I don't see the backup-batterie in...
Sep 07, 2010 | Symbol MC9090 Mobile Computer Portable...
AP Wireless Network issue with MC9060
TRY TO UPGRADE THE AP FIRMWARE
Nov 09, 2009 | Symbol MC9060-G
How To Reformat my MC9060-G !?
If you have access to your MC9060 handheld SD card (below keyboard), download and unzip 9060LenUP040300.zip from http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11488&sliceId=&dialogID=189014909&stateId=1 0 189012464 to the root directory on SD card, Full charge the battery, and run OSupdate.lnk, 4 - 6 minutes and Voal?!!! fresh and updated WM2003 OS............
Nov 08, 2009 | Symbol MC9060 Barcode Scanner
How to install the backup battery for a Symbol MC9060
Sep 23, 2009 | Symbol MC9060-G RFID RFID Reader - P/N...
Need help upgarding MC9060 with CE4.2 to Pocket PC 2003, need to change OS
Not all units can be upgraded. It depends on the configuration. Also, there may be an issue with the license.
For a complete answer to your question contact Lexicon Technologies.
Phone: 1-800-678-1744
Email: techsupport@lexicontech.com
Web: www.lexicontech.com
Aug 18, 2009 | Symbol MC9060 Computer (P/N...
MC9060
you can currently use wep or wpa(tkip)
Sep 10, 2008 | Symbol MC9060-G Portable Terminal
Symbol MC9090 Mobile Computer Portable Terminal Logo
1,564 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
