Question about Sony Ericsson Walkman® W880i Cellular Phone
The ring tones not working neather is my music or key pad tones
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
I download musics on Motorola. i want to use musics download as my ring tone. how? i need steps to use music downloads as ring tone
Go onto the music download and click on it then before playing it look at the options they'll either be "set as" or settings. Go on settings or set as and set it as ring tone. If this doesn't work or them options don't appear go onto your main menu and go on either settings or if your phone has one a ring tone setting. Then go onto sound settings. Then click on it and on there should be your downloaded music NOTE: Make sure it's on your phone not stored on your memory card.
Hope I helped Dr Reed
Apr 05, 2010 | Motorola Mobility RAZR V3i Cellular Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
My phone doesn't ring.
has it gotten wet? have you tried restarting it and taking out the battery? It could just be a faulty phone if that didn't work and it hasn't been wet. you can get it replaced most likely
Sep 21, 2009 | Pantech Matrix Cell Phone
Cellphone does not ring, or message tone
well you say that the music player is working..so there isnt any problem with the speakers..I suggest you better check de settings -> tones -> incoming call ! or settings -> tones-> incoming msg..check as they maybe switched off..that is de only possiblilty that i think maybe the problem..
May 25, 2009 | Sony Ericsson W890i Cellular Phone
How can i move music to ring tone file
You don't need to move the music tone to a ring tone file in order to use it?!
You can edit your profiles, when choosing the ringtone for any feature i/e phone - Browse, which will show you all tones including your music folder and it will allow you to choose any saved music tones here
May 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Magix Ring Tone Maker 3
search your music files. select all files drag it to Magix ring tone maker Icon
Mar 02, 2009 | Magix Ringtone Maker 3: Windows
My own musics to ring tunes, LG TU500 cell phone?
jjjhhh91,
go to ur gallery,highlyt the music that u want 2be ur ring tune,then press option,then find the use tone,then select 'use as a ringing tone'..
Apr 07, 2008 | Cell Phones
Sony Ericsson Walkman® W880i Cellular Phone Logo
22 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
