Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
My GE Harmony washer makes a screeching sound when filling with water. When the load starts to spin, it goes out of balance and must be manually restarted. How can this be fixed.
fanny
  • 146 Answers
SOURCE: G.E front load washer Mo# wbvh6240fww
The door interlock may be faulty. Try closing the door firmly or hit the door handle when the door is closed.
Posted on Oct 31, 2007
  • 249 Answers
SOURCE: Walking during the spin cycle
IT must be a fault design, fault front loaders at the best of times move, at high speed spins.ire. you have done everthing that i would done
Posted on Nov 24, 2007
  • 122 Answers
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Posted on Nov 22, 2008
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
SOURCE: GE WSSH300G0WW front load washer
WOW - I pulled out ton of lint and probably $5 in change. THANKS
Posted on Apr 08, 2010
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine not spinning, just screeching.
It sounds like the belt is slipping and will need to be replaced.
I hope this helps. If I can help in any way please let me know.
Mar 20, 2010 | Maytag Atlantis MAV9501E Top Load Washer
When spinning, Out of balance message occurs, then the machine starts to add water to get the load out of balance. It will put additional time on the wash cycle. It will drain and try to spin again. Then...
it could be weak shocks for the drum or the springs. you can also overload the washer. there should be a gap in filling washer with clothes around 5-to 6 cm's on the drum ring this gives space for movement and balancing. the washer can also become out of balance if the bearing is damaged, if you can lift the drum from the bottom of the ring and it moves up and down by few millimeters and feels lose then its usually a sign the bearing is weak. this can make the display say there is a problem with balance. 6kg or 7kg is the weight of the clothes and water not the clothes. over loading the washer damages the bearings and put more pressure on the shocks and springs.
Jul 03, 2017 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Our clothes washer has a bad screeching sound & loud spin cycle
screeching sound generally form a bad pump, which if didnt pump out correct amoun tof water would probalby send off balance more. unplug unit, ddrain out asmuch wateras possible and tip unit back, you will see the pump in the front right corner, there is a small plastic reles tab, after releasing it the pump simply twists out counter clockwise, perhaps ther is something in the pump/sump. you will see tis when oyou remove the pump, simply reinstalls the same way
Jan 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Noise
Eileen, If the screeching is only happening on the fill and not during agitation or spin, I think we are safe to rule out the belt, pulley and bearing. Remove the fill hoses from the back of the washer and check to see if you have sand or gunk caught in the screens of the valve itself. If they are clear sounds like the water passing through the valve is making the noise. Another thing to check is the water pressure in the house. It should be around 55 psi., 75 psi max. I have seen it as high as 120psi with a bad regulator. This will cause noise and all kinds of problems. The part number for the fill valve is 131389300, according to the model posted....Catriver...post back.
Aug 27, 2006 | Frigidaire FWS833A Top Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
