Question about Canon PIXMA MP160 All-In-One InkJet Printer
Mp160, doesn't except the paper , seems to get crinkled on it's left corner initially, but no paper gets past the innitial stage., I've tried the maintenance J and B and still no luck
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
HP 1300 -- toner is smudged along the left edge after crinkly sound
Hi:
This is a common problem with some HP printers. The fuser sleeve inside the fuser assembly gets torn along the edge and print can no longer be fused in that area and the paper will crinkle there. The only solution would be to replace the fuser, which for that printer it would not be worth repairing.
Andrew
Jun 08, 2012 | HP LaserJet 1300 Printer
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
The upper left corner of the paper crinkles & tears as it goes through the printer, also image is skewed.
Feed roller problem. Check for obstruction and clean rollers with alcohol swab. Roller or gears may be at fault, then it's time for a new priner.
Dec 29, 2009 | Office Equipment & Supplies
Paper catching
the paper sensor could be bad, try manually selecting the paper type, plain paper etc...
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't grab paper.
Take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer.........
Good Luck
Mar 04, 2009 | Canon PIXMA MP160 All-In-One Printer
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
