Question about Garmin GPSMAP 60CS GPS Receiver
Garmin GPSMap 60 CSx USB Connection
I have just purchased the Garmin GPSMap 60 CSx bundled with the MapSource US Topo CD and USB cable. I have installed the setup USB drivers and my computer recognizes the device when connected via the USB cable. I've switched to Menu/Settings/Interface and it displays "Connected". I open up the Maps software and select File/SaveToDevice and my only option is com port. When I select the USB Port tab it displays "No Compatible Devices are Available". Issue is I can't make it recognize the USB Connection. The software is only looking for the COM port connections. I have to believe it should work with the cable the package was bundled with, so what am I doing wrong? Many thanks in advance! RRowe
  • 1 more comment
  • Rodzo Sep 30, 2008
    Same exact problem... this unit used to work fine. I tried switching USB cables and tried connecting to another system. Then I upgraded to a new MapSource (6.14.1). Still no dice.
  • Anonymous Mar 14, 2014
    I just installed the garmin topo west cd on my computer and it has base camp with it, no when i plug in my gps it shows no device connected.
  • Anonymous Mar 25, 2014
    connecting usb cable in place of com port
Actually, I just solved the problem myself...
I went to Garmin's driver download site (http://www8.garmin.com/support/download_details.jsp?id=591) and got the latest USB driver (2.2.1) for the 60C. (Although, it appears that that driver pertains to all Garmin products, not just the GPSmap series or the 60C.) Installation instructions are pretty much standard for Windows drivers, so it's easy.
That: a) Garmin requires special USB drivers for their product is finicky (most USB-connectable products just connect automatically using Windows' generic USB driver), and b) my unit -- which had always worked just fine, and suddenly stopped connecting out of the blue -- remains a mystery. Nonetheless, a driver upgrade was the final step that I needed. (Although, I also swapped USB cables and upgraded MapSource, too, so maybe it's some combination of those things.)
Posted on Sep 30, 2008
CroceF- I just opened up a Garmin 60CSx and found that one of the contacts came un-soldered from the board. I placed the contact back on the board and heated gently until solder paste began to melt. I pressed down on contact gently and let cool. I reassembled unit and still no connection via USB. I am stumped.
Posted on Oct 10, 2012
The problem could well be a disconnected usb port. Carefully disconnect your cord from the unit by pulling straight out. Carefully inspect to see if the port extends past flush with the case. If it does it has become seperated from its little PCB inside the unit. It will need to be resoldered. This is where my help ends. Garmin no longer stocks the part so repair is only option. The case is easy to open and the part easy to remove but I have found no one who does this type of precision soldering work.
Posted on Feb 26, 2010
  • Garmin Master
  • 638 Answers
Firstly, you should update your Mapsource program to the latest version 6.13.7, I think.
Select your maps using the Map Select tool.
Transfer > Send to Device
A window should pop up, hit the button [FIND DEVICE] and it should search for the unit.
Please let us know if this cures the problem.
Posted on Apr 04, 2008
Chat session ended by mistake. I need help with getting my Garmin GPSMAP 60 CX up and running. 1. I have successfully loaded Trip and Waypoint Manager on the computer 2. I have the unit hooked up to the...
You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
Jan 06, 2011 | Garmin GPSMAP 60CS GPS Receiver
How to plot my map in this gps
The 60 CSX dosent support custom maps but if you are looking to plan a route or plot waypoints the easiest way is to acquire a copy of Garmins TOPO disks and do all of this on the PC. You can also do this on the unit using " Mark Waypoint".
Hope this helps!
Dec 10, 2010 | Garmin GPSMAP 60CSx GPS Receiver
I cant unlock the map detail garmin topo aus/nz , ive registered and received the 25 digit code but mapsource and basecamp wont recognize it? thanks
Your'e lucky, I can't even get the unlock code. If GPS not reg when unlock started then u can't get email & garmin no help.
Nov 20, 2010 | Garmin GPSMAP 60CSx GPS Receiver
WE HAVE PURCHASED A ETREX GARMIN BLUE IN COLOR AND ARE WANTING TO KNOW HOW TO GET DOWN LOADS FOR MARINE WITH OUT PAYING FOR THE CD OR DOWNLOAD
You need Garmin MapSource (Trip and Waypoint Manager) and a data cable. Then for free maps visit the murky internet sites and beware of what you download. I would not bother with a topo or marine maps on a grey screen GPS anyway as the colour maps will not be easily understood on a grey screen.
Aug 28, 2009 | Garmin eTrex Legend GPS Receiver
HOW DO YOU LOAD MAPS TO THE GPS UNIT?
You will need to load the MapSource software on your PC then load the maps into MapSource. After the maps are loaded and unlocked you can plug your GPS into your PC with the USB cable and load the maps.
Hope this Helps.
Jul 24, 2009 | Garmin eTrex Legend GPS Receiver
GPS position is offset from map location
This could be because your datum and your posistion format. Under your menu go to setup, then units and make sure you have the correct info set in there for your area. NAD27 Canada would be the one you are looking for. Give that a try and see if it works. If it is still off, consult the manuals that came with your topo and see if it says what datum it uses.
Nov 15, 2008 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Garmin gps60 connected to PC
You have the USB cable but what software? Have you got the MapSource CD? If not, there's a free and legal workaround. Download the free Garmin Training Center (from Garmin site), open it to check it works, close it then download the Mapsource update file, also from Garmin site. You'll now have MapSource and can uninstall Training Center. You'll need maps though - depending where you are there's some free maps otherwise get a Garmin map to make it easier to plan trips.
Oct 26, 2008 | Garmin 60 GPS Receiver
Connection issues
yeah , i am with garmin 196, and usb to rs232 cable and instaled driver, but it wont connect ..... anybody help ?
Aug 30, 2008 | Garmin GPSMAP 60CS GPS Receiver
Do Not have installation Disk For Mapsource United States TOPO
Sir
i have garmin gps 76 csx but i dont have its sofware with me and i want to transfer all the data and save it on my pc.
but as i dont have the cd with me i am in problem so plz solve or give the solution
thanks
Aug 03, 2008 | Garmin MapSource United States TOPO...
General confusion with plethora of maps etc
If you have a copy of mapsource read the help file
"Transferring and saving mapsource data"
if the data will not on your (micro)SD card use a bigger one
Dec 25, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60CS GPS Receiver Logo
4,291 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
