No sound from Sanyo model GXT848U stereo unit. Circa 1988. Worked fine. Just failed when turned on today. No sound from speakers, or headphone jack
Widiantoro
  • 15 Answers
SOURCE: Headphone Jack Problem
install (update) the compatible sound driver for vista.
Posted on Dec 01, 2007
COWBOYPOL_06
  • 13 Answers
SOURCE: no sond from speakers but with headphone jack
there is no problem with the amplifier audio,check some resistors or disconections near the spkr terminals.
Posted on Oct 21, 2008
SOURCE: i have a yamaha rxv663
wireless speakers will usually hook to speaker outputs as well as headphone jacks. hook the wireless speakers up to speakers "b".
Posted on Dec 17, 2008
  • 121 Answers
SOURCE: Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Posted on Feb 26, 2009
rulds2008
  • 3866 Answers
SOURCE: Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Posted on Apr 22, 2009
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Headphone jack on my compaq presariocq62 is not working
hi
maybe you have loss in jack connection otherwise check sound setting in volume bar right corner of desktop
Dec 04, 2012 | Compaq Presario 700 470024-192 Notebook
Sanyo dp55360 sound oscillates through speakers, sound fine through stereo
Check whether the sound is ok on a headphone, if the TV has the socket. If this is not ok, the problem lies in the sound output section. Some capacitors are leaky/dry and/or power supply to that section is irregular. Needs attention by a qualified service technician.
Aug 06, 2012 | Sanyo Televison & Video
Acer aspire one sound not working
Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
May 23, 2012 | Acer Aspire One Netbook
Keeps clicking between speakers on and hp input on...no sound
had same problem with my denon 1910 .... clicking with no sound and some modes indicating not available. Blowing the dust out of the headphone jack solved the problem !!!!!!!!!!!!! ... the denon people could not even figure it out. Thanks sooooo much.
Dec 30, 2009 | Denon AVR-589 Receiver
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
95 Ford stereo speakers stopped working
i'm guessing that is premium sound... check the relay for the amplifier.. or bass booster ... can't remember what it was called on my windstar of that year but when i blew the fuse i had no sound
Mar 23, 2009 | 1995 Ford Club Chateau
Mitsubishi tv volume on tv not working
If the TV has stereo sound, there may be a speaker switch for internal/external speakers on the rear of the TV that may have gotten bumped by something. (kids, pets, something fell behind?) If no switch, the sound driver chip or speaker may be failed. If the speaker is the culprit, headphones would still work if there is a jack for headphones. Might be a good time to consider a new HDTV
Dec 22, 2008 | E-Machines eMachines Desktop PC
No sound from speakers.
Hi...
On some stereo gear the headphone jack interrupts the speaker connection when the headphones are in. you "might" have something broken in the headphone jack which is keeping the speakers from turning on.
Is there a MUTE switch on the unit?
Or an "External speaker off" thingy in the menu?
Sep 07, 2008 | JVC TH-M303 System
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
59 people viewed this question
 Grubhead
Grubhead
