Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Blowing air out
Our vacum is blowing warm air out and not sucking up any of the water. What should we check?
  • 126 Answers
Re: blowing air out
Blowing warm air is normal for these machines. The suction problem is probably a result of the lid on the recovery tank not being installed correctly. Take the lid off the tank. If you look at the top/front of the tank, you will notice that there are two "tabs" at the corners. These tabs insert into the lid and hold the front of the lid in place. You then fold the lid down towards the back where there is a latch on the lid that locks the lid in place. It is a very common problem that people don't get the front engaged properly and the suction leaks out there and never gets to the floor. The motor will produce heat as a natural byproduct and is not unusual.
Posted on Jan 13, 2008
    Problem Solver:
  • 4 Answers
Re: blowing air out
This was, by far, the best written, directional solution! Thank you som sanity has been restored!
Posted on Mar 07, 2009
0 characters
3 Points
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Fantom Fury vacuum does not pick up dirt. [The
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
May 01, 2010 | Fantom Vacums XT450K Upright Vacuum
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Blowing warm air
Is there a part missing on the front of the dirty water tank? On some of these machines, there is block that you take out so you can insert the hose in its place. So if this spot is open, then it can't suck and will be blowing warm air.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Spin vacum won't suck up water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid is not locked down all the way.
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
312 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
