Question about GE Refrigerators
GE model GSH22JFTA will not defrost.. mother board has been replaced twice and now I'm being told there is a broken wire in the wall leading to the m-board. Can this be fixed??? I was told no??
catriver
  • 878 Answers
SOURCE: GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
Posted on May 30, 2008
Just_Bobz
  • 448 Answers
SOURCE: GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
  • 1218 Answers
SOURCE: GE GSH25JFTA BB getting VERY warm on defrost
Good day,
Your machine should have a limit thermostat as well as the thermister. It may payto change it first before the motherboard.
It looks like this, mounted on the top of the coil.
If that fails, and the machine goes back to normal cooling until the next defrost cycle, I can think of nothing but the motherboard as the culprit.
Posted on May 29, 2010
caroldon
  • 17129 Answers
SOURCE: GE model #GSS201EMBWW is not defrosting, checked
The drive output - solid state relay maybe a thyristor - is short and is continuously heating the element thus burning it off.
The element is supposed to heat only for a specific period of time. The motherboarrd must be taken out to confirm the shorting of the thyristor/SCR.
replace with the same type and it will only swittch on when the microprocessor timer signals a bias to turn it on.
Posted on Aug 30, 2010
aasc
  • 1606 Answers
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Aug 31, 2010
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
GE Profile freezer won't maintain temperature
clean the dust from underneath and make sure fan in freezer is working.
Feb 06, 2014 | Refrigerators
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Aug 14, 2012 | GE GSS25SGMBS Side by Side Refrigerator
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out....
Aug 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I have a GE side-by-side refrigerator/freezer that's not maintaining cold temperatures. I was told to replace the defrost thermostat which I did and it seemed to work for about a week or so. But now it's...
If the refrigerator isn’t cooling at all the motherboard is a good possibility burnt marks or not. If the fans are not running it could be a defective fan, motherboard or both. Take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the refrigerator isn’t defrosting properly, after a few days the freezer coils will get blocked out with heavy frost. There are four things that will cause this, defrost thermostat, defrost heater, evaporator thermistor and the motherboard. This page should help http://appliance-repair-it.com/GE-refrigerator-repair.html
Jul 17, 2010 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Our GE GSS25JFMBWW refrigerator is not keeping cold on the refrigerator side, but is keeping pretty cold on the freezer side? Any idea on what is happening?
Sound like your refrigerator is experiencing a defrost problem. Mot times this involves the defrost heater part number WR51X10055 Look into the back wall of the freezer compartment and if frost is beginning to stick to the back wall unplug the refrigerator and remove the rear panel in the rear of freezer. Defrost with a hair dryer until you can see the defrost heater below the evaporator coils. If burned out it will be easy to spot because the defrost element is inside a glass tube. The defrost thermostat could also cause this problem if defective. If you replace the defrost heater I also recommend that you replace the defrost thermostat part number WR50X10054 There is no defrost timer on your model. Defrost is controlled by the mother board, Let me know what you find, Thanks, Sea Breeze
Sep 26, 2009 | GE Refrigerators
Problem with the unit not defrosting. How do I know which part is the problem? Thermostat, heater and Bracket assembly or mother board. Is there something else I should be looking at? Thanks Dan
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is working and refrigerator side is not work.
Most times that is a sign of a defrost problem. And because yours has the defrost board made onto the mother board we will need to do some looking around for the problem. Unplug refrigerator and pull away from wall. On back there is a cover over an area that contains the mother board. With power off take the board loose and examine the board for burn marks, sign's of heat or melted away solder connections. If the board looks OK the return it to its place and remove the rear panel in the freezer section. Need you to disconnect one end wire on the defrost element/heater. Check continuity through the heater to make sure there is no burnout. The defrost thermostat is connected to one end of the defrost heater. The contacts are open when the temperature is 50 degrees or higher, so testing it would look bad above 50 degrees. Just look to see if there is any deformity. If defrost thermostat is defective it will not allow the defrost heater to engage or to remain on long enough. Let me know what you fins. Sea Breeze
Jun 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
2006 ge side by side model 22
Rarely is a defrost problem caused by the mother board. (but it can happen) The most common cause is the glass tube defrost heater. I'd unload the freezer section, take the evaporator cover off (ie: the back wall of the freezer section) and ohm test the defrost heater at the bottom of the cooling coils. (ie: the evaporator) To do this, remove the push on wires and see if you get a ohm reading. Sometimes you can visually see a bad defrost heater, but the resistance check is your definitive test. You did not list your model number, so I can not list a part number for you. A defrost issue can also be cause by air leakage, such as a poor door gasket or a door which was not completely closed.
May 10, 2009 | Refrigerators
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
