Question about Intel Desktop Board D865GBF (MBIND865GBF) Motherboard
Hi.. i want to connect two computers thriugh lan cards. i need the cable specs and all the things i have to do....
    Scholar:
  • 53 Answers
First, make sure you have a crossover cable a normal cat5 cable will not work. As for setting up the network, here is a simple tutorial that is step by step and aimed at the novice user.
http://www.leeindy.com/connecting_two_computers_using_crossover_cables.shtml
Good Luck!
Posted on Sep 23, 2009
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Jun 11, 2011 | Computers & Internet
So I just got a Dell Optiplex sx280 that runs windows xp and can't connect it to the wireless internet at my house. The built-in driver is a Broadcom NetXtreme 57xx Gigabit Controller, and I don't...
Desktop computers do not usually have a wireless card installed. They will have a built-in LAN card that uses a LAN cable.
If you want to connect your computer using a wireless connection then you will need to install a wireless card in your computer and configure it to communicate with your wireless router.
Otherwise you can connect to your wireless router using a LAN cable.
Your wireless router may have built-in LAN ports and you can connect your computer to the wireless router using a network cable.
Jun 09, 2011 | Dell OptiPlex SX280 PC Desktop
What is difference between lan card and modem
The difference between a Lsn Card and a modem are this - A Lan card is a card that you slide into the side of a laptop and it can allow you the ability to get onto a network wirelessly. A Lan card for a PC allows a Lan connection by way of a CAT 5 cable that will allow you to get onto the internet or if a crossover cable is attached to your pc to another you are directly connected to the network. A modem is a piece of hardware that is installed into a slot in the PC that will allow you the ability to get onto the internet by attaching a phone line to it through the RJ 11 jack (which it comes with 2 rj11 jacks on it).
Here is the picture of LAN port and Modem port
Dec 24, 2010 | Siemens Computers & Internet
Wireless connection to internet works. But when I take the eMachine 260 notebook computer to another location with only a LAN cable, the LAN connection to internet doesn't work. What's wrong?
hi there, first thing is to check if drivers for your ethernet is installed in your computer. you can go to control panel then system then device manager then look for network adapter. your ethernet device should be present there tand there is no exclamation point in front. if LAN device is not present, or with exclamation point, you may try reisntalling you LAN card drivers to fixed the issue. you drivers must be located at the driverdisk that came with the system.
thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 14, 2010 | E-Machines 6809 Notebook
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Not connecting to landcard
hi there
Can you be more specific about this problem so i can help you. there's could be
couple of things that can cause this problem ie. computer not recognize the card or your computer is not set up properly.
Nov 16, 2009 | Computers & Internet
My internet provider says i need a lan card what is this? and how do i get it
You can buy Lan card at any computer store, just give them the spacification of your computer and model, they will give you the Lan card compatible to your computer.
Lan card is a board that you will attach to *********** board, it have an connector for you lan cable so that you can connect to a modem to connect to the internet.
Nov 04, 2009 | Dell Computers & Internet
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Lan
If you are referring to the Ethernet cable, initially, it can then be presumed that your computer then has no LAN port. What would be required is purchase and installation of an add-on networking card. Although it is quite rare for most modern desktops not to have a built-in LAN port. The image below is an example of an add-on PCI LAN card
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
