Question about Nintendo DS Lite Console
U need a new screen in the bottom, try to get a nintendo brand screen instead of an aftermarket.
Posted on Dec 15, 2007
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
Jan 08, 2010 | Nintendo DS Lite Console
Nintendo DS lite bottom screen is white.
Sounds like the screen is broke. Before you change the screen you may want to have a look at where the LCD ribbon connects to the motherboard it may be loose. It would be worth while opening the DS and disconnecting and then reconnecting this ribbon to see if it solves the problem before ordering a new ds screen.
Mar 22, 2009 | Nintendo DS Lite Console
The AR should come pre-loaded with codes for most games. If you followed the directions carefully and there are no codes for your game I suggest following the AR update instructions in the booklet to reset and download the most up to date codelists for your games.
Dec 12, 2008 | Datel Action Replay for Nintendo DS
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
My sons ds lite won't turn on - the screen flashes
hey there Mike to me it sounds like one of the ribbons inside became loose or there is a blown fuse in your unit both are fixable you can check the ribbons and also the fuse can be bridged as well if your unit is under warrenty please contact nintendo about this and get a RMA for the unit if it is not under warrenty then there is two solutions to this either get a repair tech to look at it "can be found in the fixya repair directory" or we can work it out together if you need to know the steps required to fix the unit.
Nov 28, 2008 | Nintendo DS Lite Console
I CAN SOLVE IT xD no its not broken
heres what u do :D You hold A+B+START+SEL With action replay in then you turn it on while holding Those buttons then when Action replay main screen comes up Release the buttons and then type ID in then it should work
Nov 27, 2008 | Nintendo DS Console
Ds lite
when i turned on my DS lite it went to the action replay screen but there was no games entered so i tried to add the game it worked sort of when i put my game ID in for pokemon pearl the bottom screen started showing blue and red lines
Sep 06, 2008 | Nintendo DS Lite Console
Ds lite
Sep 03, 2008 | Nintendo DS Lite Console
Dim bottom screen on DS Lite
There should be either a button or a setting to adjust the lighting, try doing that.
Dec 01, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
579 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
