Question about Kenmore 42822 Front Load Washer
My Kenmore 42822 washer goes through a cycle and quits with 1 minute left on the timer.
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question**%$%$^&^
Posted on Oct 01, 2010
Why does my Kenmore HE3t front load washer always take more time to finish then what it says on the timer?
Check the filters in both ends of the hoses. If they are clogged, it will throw the timer off. If it figures on 2 minutes to fill but it actually takes 6 or 7 minutes, the timer won't be accurate.
Jan 20, 2013 | Kenmore Elite 45986 Front Load Washer
My kenmore elite quite pak 2, HE3 shows F then H and quits the cycle.
The FH error code mean that no water was detected entering the machine.The things to check are,a pinched or kinked water hose into the washer, the faucets off or if faucets on make sure that something has not restricted the water flow through the hoses..this will be possible espically if they washer is connected using "AQUA FLOW FLOOD STOP" ..the internal flood stopper will cause water flow to be cutoff for no reason. Also check the filter screens on the back of the washer where the fill hoses connect to,for debris in the screens.
If all above checks ok i would suspect the part called the FLOWMETER was defective in the washing machine.
GENE
Aug 28, 2011 | Kenmore 42822 Front Load Washer
Kenmore Elite model 42934. Problem washer only
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 26, 2010 | Kenmore 42822 Front Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Front load washer wcvh6260fww
The problem may the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Mar 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Dec 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 42822 Front Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
