Pre-out for sub in-op
Can't get anything from my pre-out for my sub. Sub is toggles "on" in speaker set-up. Any other tricks, or could the pre-out be bad?
  • chasleyko Dec 15, 2007
    Sub is powered, hums when I touch RCA plug, sub is toggles to "on" in speaker set-up. Isn't pre-out basically just a line output? and how would it go bad?
  • 231 Answers
First make sure the actual sub is powered on .You can tap on the RCA leading to the sub and hear the sub humming..Im assuming you do have a powered sub connected to sub out of receiver .Also you could also connect another type of speaker with RCA to make sure if it has output or not..Also make setup does have sub output ON..thanks
Posted on Dec 15, 2007
  • crispin melchor Dec 15, 2007
    yes sub-out is just a line level output but just outputs low frequencies thus'sub out"..well as far as how its not working ..hard to tell .unless preamp board is small board inside and not seated properly to other boards..if you have owners manual .you can try to reset unit and see what that does..if unit has other variable pre-outs that are working .then you can you use one of those pre-outs and connect a line level low pass RCA filter.that way it filters out high/mid frequencies and passes only the low frequencies to sub..
Connect skytec subwoofers passive speakers
Be sure the sub pre-out is intended to drive a powered sub (RCA to RCA). Is there a sub power indicator on? If not, there may be a blown internal fuse. Also some custom speaker configurations such as speaker size can override what you think you want to do.
Feb 01, 2014 | Pioneer Audio Players & Recorders
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
May 20, 2011 | Harman Kardon AVR 135 Receiver
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
Feb 05, 2011 | Technics SA-EX500 Receiver
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
I just bought a KEF PSW2500 subwoofer and am trying to connect it to a Yamaha v663 receiver. However, I went from a subwoofer pre-out 1 to the right line in on the sub. I don't hear any sounds from the...
HI,go into the yam setup menu and make sure you have the sub turned on and cross over set to about 80hrtz if this suits your speakers,set sub level to about -5 on amp and say half way on the sub,this should work if not pull out sub cable at amp and touch the end,you should get a hum,if not you may have no power,faulty cable or sub.
PS>make sure you are pluged into the sub PRE OUT and NOT the six channel in.
Hope this helps.
Apr 19, 2009 | KEF Audio PSW 2500 Subwoofer
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
Apr 02, 2009 | JBL PB12 Subwoofer
No Sub Woofer Pre out output
I've got the same model and the pre out transistor needs to be replaced,
sometimes you can get it to work by unplugging the reciever and the pre out
then plug in the reciever and plug the pre out in a couple of times or so untill it comes on
or unplug the amp from the wall then plug in the pre out , turn on the reciever wait for sounds to come on then plug in the amp.
if that don't do it the pre out transistor needs to be replaced
Oct 16, 2008 | Pioneer VSX-D511 Receiver
Wiring sub on home theatre
use the sub pre out and wire it into the left input on the sub.
Mar 08, 2008 | Audio Players & Recorders
429 people viewed this question
