Question about Kingston 4GB Secure Digital High Capacity Memory Card
I want to format my card but it cannot be detect by the computer even I removed it from my camera, Samsung i8. When I insert back to the camera, it shows "CARD ERROR" and unable to work. Help me ):
Posted on Oct 07, 2009
  • 154 Answers
Try using a Card reader, card reader is like a plug and play device.
Posted on Sep 23, 2009
  • 73 Answers
You might try to use card reader to try to read it and format. If there no sucess it might be that its broken. Moreover in your camera ther should be formating option too.
Samsung i8 windows 7 drivers download
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Feb 23, 2012 | Samsung i8 Digital Camera
The slide in the sd card is missing?
Try inserting the SD card into the camera and see whether it'll be detected.If not,you may have no option but to use another SD card.
Thanks!
Jan 01, 2012 | Samsung Cameras
I can't download pictures from my Samsung i8 camera. It might be the USB connection to my laptop? I've tried to use 2 cables provided (joined together) to make a connection, but the laptop isn't...
Will it work on another computer? If so, it's probably a corrupt driver. If the camera is working fine, you may want to just use a memory card reader instead. They are inexpensive and read pictures faster than the camera itself. It is an extra step to remove the card each time but is less than a new camera.
Feb 03, 2011 | Samsung i8 Digital Camera
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
This camera reads "card error" and won't format a
yes. you can try to insert the sd card to a computer using any all-in-1 memory card reader. then if windows detects it, right click the card's drive in windows explorer then select format. choose FAT as file system type. before you put it back to your camera clean the card's contact points, insert the card and if the camera detects the card format it again using the camera's format tool.
Dec 19, 2010 | GE C1033 Digital Camera
When i insert the memory card "card error" appears
Please try this card with your PC and if there is any issues in detection after inserting into the card detection slot, then the card is faulty for sure.
If not make sure there are no foreign particles inside of the slot, make sure with a good air jet the slot is clear.
If there is no detection remove battery, keep it off for few hours/overnight and retry.
If the fault stays the fault is in the interface to the processor in the main board.
Nov 24, 2010 | Samsung i85 Digital Camera
How can i put songs in my camera samsung i8
remove memory card from your camera after a wyle insert your memory card to the card reader then plug in to your PC start download
Apr 02, 2010 | Samsung i8 Digital Camera
Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Jul 06, 2009 | Kodak EasyShare C875 Digital Camera
My pc(XP operating system) does not detect my digital camera
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 06, 2009 | Samsung Digimax S630 Digital Camera
SD Card in Nikon F10 not recognised by XP
It could be one of two problems. The most likely is that the card reader you are using cannot read SDHC cards, of which all 4GB and larger cards are. Try using the camera's cable to download to your computer directly to the USB port. I bet you'll find that it works that way. The other problem could be (but not likely) that you are shooting on the RAW file format, instead of the jpeg file format. Most software cannot recognize RAW files, but jpeg is pretty universal.
Mar 19, 2009 | Nikon Coolpix 8800 Digital Camera
Kingston 4GB Secure Digital High Capacity Memory Card Logo
136 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
