Question about Cell Phones
How to convert cdi 53 to cdi 52 - Cell Phones
ML 320 CDI 2008 Model. Car cuts out while driving, fault code: fuel rail pressure low.
it needs a cat converter to enable the ECM to function properly next low fuel pressure can be from EVAP system not venting the tank properly, failing fuel pump or faulty pressure regulator unloading too much fuel and dropping the pressure
at this point I would be looking at the EVAP system , then the pressure regulator
Nov 06, 2016 | Cars & Trucks
Hai, I'm Nathan from Kidapawan can I convert a DC CDI. to an AC CDI. with instructions?
Hi, Nathan for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
AC to DC CDI swap GY6 clone
Tech Talk with Mo
http://www.jr-richscooterdoc.com/Help_electrical_explained.pdf
anyone installed an AC cdi
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 08, 2016 | Motorcycles
How to convert the 5 wires into 4 wires on a 2008 Yamaha TZR 50 racing cdi @
Hi, Athaniel the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to convert the 5 wires into 4 wires on 2008 Yamaha TZR 50 racing cdi...
CDI wiring Honda
Yamaha TZR50 03 Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
Yamaha TZR50 Owner Manual
Feb 11, 2015 | 2008 Yamaha TZR 50
Manually reset convertible top
Could be a fuse too. Definitely electric
Mar 20, 2014 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
BANK 1 SENSOR 2
bank one is the passenger side catalytic converter,,,sensor two is the lower oxygen sensor
May 14, 2010 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Hi Where is the bosch 13782 oxygen sensor located on a 1998 Mercedes E320? Thanks
all oxygen sensors are located on the exhaust pipes. depending on the specific configuration, there can be 2- 4 sensors. always will be a set before the catalytic converter and a set after the cat. converter.
Aug 13, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Convert a 1977 xs750 points to electronic ignition
You will find everything you need to know about this here:
http://www.yamaha-triples.org/forums/thread-view.asp?tid=5399&posts=18&highlight=electronic%20ignition&highlightmode=1#M40996
I am probably going to do the same to my 77 xs750 this weekend. Dusty6467
May 15, 2009 | 1985 Yamaha XJ 700 X Maxim
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
