Question about Garden
Cant turn steering wheel will work for a while then goes completely around, with a little nudge it will turn but not for long. can you help me,
  • Chuck
    Chuck May 11, 2010
    MAKE - MODEL - SERIAL NUMBER?
  • 472 Answers
SOUNDS LIKE THE GEAR IS STRIPED OUT MAY NEED REPLACED
Posted on Oct 08, 2009
The key is programmed to the car and unlocks doors and locks them but when trying to start the car the immobilizer kicks on and shuts the car off. how do I reset the key? ive done it before by doing...
get the car to run then remove the chip from the key and remove the shroud around the steering wheel and tape the chip to the transponder ,then its permanently activating the immobilisor and no more problems .Just buy a decent steering wheel lock in case anyone works out whats been done .nudge nudge wink wink dont tell anyone what you have done not even your own mother
Nov 10, 2012 | 2006 Volkswagen Jetta
1999 ford explorer limited whining noise in front end
Whining noise is probably in one of the pulleys or belts. Probably the power steering. And the popping is probably CV axles.
Aug 02, 2012 | 1999 Ford Explorer
A loud clunking noise when turning the steering wheel and now the steering wheel just goes around and around
Either your steering gear failed or the connection joint between the steering wheel and steering rack input has broken. Since you have turned the wheel around in such a way, the clock spring for the air bag will also need to be replaced or you can have accidental airbag deployment or it can fail to deploy in a wreck.
Mar 01, 2011 | 2003 Saturn ION
Have a 1887 pontica grand am cant get the ingition swicth out what can i do
Take the shifter and push it up past park. That usually works, Or give the shifter a little wiggle. There is a locking system in there that can cause the key not to fully go to the off position.
If it does go completely to the off position, then the pins in the ignition switch could be stuck and a lite tapping with a ballpeen hammer around the switch can loosen them up.
Sep 02, 2010 | 1997 Pontiac Grand Am
Turn single only workes when i turn the hazerlight on then shut it off
I had the exact same problem w/ my 2001 Jeep Grand Cherokee. Fairly simple fix. It is the flasher relay, OEM Mopar Part #4686094, pay around $45 for the part at the dealer.
Take kick plate trim off (3 screws and clips holding it on) remove fuse cover (pops off) remove plastic shroud in front of steering wheel below the instrument gauges(pops off) remove large plastic shroud under steering wheel, (2-10mm bolts, clips and one phillips screw holding in place). Relay will be above fuse box, very tight fit but with a little nudging and nimble fingers pop out the old relay and replace with new one. Re-install all equipment in reverse order. Solved my turn signal problem immediately. Good luck
Mar 22, 2010 | 2001 Jeep Grand Cherokee
02 Santa Fe: Steering hard after going through deep puddle
chances are the belt is getting so wet its slipping on the pulley causing you to lose power assist temporarily
Apr 15, 2009 | 2003 Hyundai Santa Fe
Key will not turn in ignition
I would try and nudge the steering wheel around a little first. Sometimes the steering wheel can be in a bind and prevent the ignition lock from turning. Try and turn it to the left/right and/or push down/pull up on the wheel.
Thank you for your question, please let me know what happens.
-Mike
Apr 06, 2009 | 1996 Ford Taurus
The volume in my Lincoln LSE (2002) goes off when I turn the steering wheel. Also my steering wheel radio controls are not working? can you help
After countless hours of research and nothing, I just decided to start playing around wtih the steering wheel. While in park I turned it all the way to the left and then to the right and low and behold the volume as well as the media steering wheel controls started working. I am sure its a loose wire but since money is tight this is a short fix for now.
Good luck to anyone else who may have the same problem.
Dec 28, 2008 | Audio Players & Recorders
Loose steering coluimn on 88 camaro
your steering column has a plate with 4 inverted torx fasteners I believe they are e8 fasteners, you must remove the upper tilt flange to gain access to these bolts , a few special tools will be needed : Pivot pin puller , steering wheel puller , lockplate depresser to name 3. the job takes about 1.5 hours to complete. hope this helps a little.
Dec 19, 2008 | 1988 Chevrolet Camaro
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
