Question about Maytag MGR5751AD Gas Kitchen Range
MAYTAG GAS RANGE MODEL # MGR5750 ADW
The supject range did not work anymore after the cleaning cycle.
An error code F1 is showing in the display.
Could you please tell me what the problem might be.
Thank you,
Mike Haring
  • pinkleopard Mar 24, 2008
    Cleaning cycle will not start. After touching the cleaning button and the control lock nothing seemed to happen and then the bake, broil, cook time, stop time and cancel all bring up the word "off" but nothing seems to happen. It is not cleaning and we could not bake or broil anything because each time the bake and broil buttons are depressed the display says "off." After fifteen seconds the word "off" also goes away.
  • Anonymous Oct 23, 2008
    f1 is on display on maytag gas range
    Sergeant:
    Champion:
  • 338 Answers
The range has sensed a runaway temperature. if you have a meter you can ohm out the temperature probe make sure it reads around 1270 ohms. if it is way off replace the temperature probe if it is close to 1270 replace the EOC. (Electronic Oven Control)
Posted on Nov 26, 2008
Display panel shows F1 Fault... how do I fix this
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 01, 2010 | Maytag MGR5750 Gas Kitchen Range
I have a Maytag Advanced Cooking System Model #MGR5745ADA that is showing a code "F1" on the display. The oven doesn't work.
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 25, 2009 | Maytag MGR5750 Gas Kitchen Range
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Have Ilve oven but have misplaced the manual and we need to know the self cleaning program instructions
Here's the user manual for the Following Maytag Range Models (It covers MGR5710 • MGR5720 • MGR5729 • MGR5730 • MGR5755 • MGR5750) =>
http://shared.whirlpoolcorp.com/assets/pdfs/literature/MGR5710ADQ.PDF
Aug 10, 2008 | Maytag MGR5750 Gas Kitchen Range
Baking display malfunction
Its likely sab as in Sabbath mode.
Here is your online use & care manual which explains all about the Sabbath mode on page 15:
http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf (http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf)
Mar 23, 2008 | Maytag MGR5750 Gas Kitchen Range
HELP PLEASE
The manual says to press "cancel" to correct an F# fault. Then if that doesn't work, unplug AC power for a few minutes and try again. If that doesn't work, the unit needs serviced by a professional.
Geno
Mar 10, 2008 | Maytag MGR5751AD Gas Kitchen Range
F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Maytag MGR5751AD Gas Kitchen Range Logo
192 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
