Question about Kitchen Appliances - Others
Bread machine automatically turn on and starts when plugged in
Bread machine automatically turns on and starts when plugged in starts going through the cycle before I get the ingredients in and after cycle completed starts the process all over again. Stop button will not stop the machine ..
My b2300 bread machine will not mix on one paddle it seems the belt is of the pully. I have taken all the screws out in the bottom but the bottom will not come off is there any more screws to come out from the inside
Posted on Sep 24, 2009
I went to plug my bread maker in Model B2500C and it started making a funny noise. Then I moved it to a different area to see if it would work better. When I plug it in it automatically starts and won't...
These are fussy models and have lots of issues - if you are still covered under warranty just contact B & D, they were great at sending me a new model after mine broke under warranty. It sounds like yours is broken beyond repair, it is likely cheaper to replace it. Try contacting the company, they should be able to help you best.
Sep 07, 2013 | Black & Decker Bread Machine
Cuisinart bread maker won't start
I hate to tell you this, but when the power returned, your bread maker may have suffered from a power surge. Sorry. :(
Nov 17, 2012 | Kitchen Appliances - Others
The machine automatically starts at 3h 20m (the length of time for white bread) but when I press 'reset' to bring time up to 4h 28m (required for whole wheat), it won't start mixing until I...
If you have a B. Crocker bcf1690 machine you need to just plug it in and it will always default to the regular bread program. To change it to whole wheat you need to press the Menu button until the whole wheat program shows on the display ( #3) according to my manual if you go past it just keep pushing the menu button until it comes back around again to #3. then just push the start button.
Jul 12, 2011 | Betty Crocker BCF1690 Bread Maker
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
Would like to know how to set machine to start at a later time
Since you haven't listed the model or make of the bread machine, there is a simple solution for this problem that will work or any make or model bread machine.
Using an "outlet timer" or sometimes known as "appliance timer" you can set your bread machine to receive power at a particular time in the day and you can even set it to turn off at a specified time too!
eliteandres.jpeg Above is a picture of what one of these devices looks like. These can be found at home improvement stores or online.
Step one: Plug the outlet timer into the wall Step two: Plug the Breach Machine into the outlet timer, and leave it in the "on" position. Step three: Set the timer to turn on at the specified time.
The bread machine will receive power at whatever time you set the timer to turn on and since its in the "on" position it will automatically start making the bread.
Feb 28, 2011 | Kitchen Appliances - Others
Timer is working but the motor (that spins the piece to make the dough) does not. Is there any security fuse ? Thanks Michel
Hi michel amor
If you are using the timer nothing will happen until the time you set for the breadmaking process to begin occurs. In other words if it 8 am and you want your bread several hours later then your bread machine will do nothing until several hours later. If you don't want to use the timer and you just want to be sure that your paddle turns and kneads the bread go ahead and push the stop button and hold it down until it beeps. Unplug your machine, then plug it back in. Then do this:
----push select
----choose your program ( for example choose #1 basic)
---choose your crust color
----choose your loaf size 1.0, 1.5, or 2.0 pounds
----push the start button
----your machine will start mixing with the paddle
----if your machine is cold it may warm up for about 15 -20 minutes but it will start mixing within 1/2 hour.........hope all this helps
Jan 10, 2011 | Black & Decker Bread Machine
My White Westinghouse Automatic Bread Machine sits for over 1/2 hour before it starts to combine the ingredients by turning. Then it turns for over 1/2 an hour and does not seem to stop to let the bread...
Hi fellow bread maker! Can you tell me which program you are using. Basic, whole wheat, sweet bread etc.?? Based on what you describe I think you may be choosing the whole wheat cycle because the stages you describe are almost exactly what my Toastmster does if I choose the whole wheat cycle. Hope this helps....
Oct 17, 2010 | Westinghouse Kitchen Appliances - Others
Bread machine turns on when plugged in and when turned off with the on/off button and unplugged/plugged- it still keeps turning
i'm having the exact same problem! the last loaf i made after it was baked it started turning and it destroyed the loaf. now when i plugg it in, it wont stop spinning!
Jan 11, 2010 | Oster 5834 ExpressBake Bread Maker
Kitchen Appliances - Others Logo
113 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
