Question about HP Photosmart M525 Digital Camera
When i switch it on says your memory card needs to be formated
When it says needs to format the memory card i did pushed ok and then nothing happen and keeps on red screen even when i remove the memory card won`t work n same msg can any one give me a hand of help plzz
  • 30 Answers
Try formating card using card reader.
Posted on Sep 23, 2009
How do i format the memory card on the kodak easy shareDX7590. I just bought and inserted a knew kodak 8 gm memory card and it says it need to be formated and i do not know how and have pushed all the...
To format a memory card, press the MENU button, use cursor-up/down to select Settings, press the OK button, use cursor-up/down to select "Format," and press OK.
The DX7590 works with MMC and SD cards. It does not work with SDHC cards. If you mean an 8GB card, then that's an SDHC card and will not work with the DX7590. The camera is limited to cards 2GB and smaller.
Sep 24, 2011 | Kodak EasyShare One Digital Camera
When i turn on my s5700 there is a message (images recorded to internal memory) then on the screen is a white box with black letters (in) i have done what the manual said and formated but it has not made...
Okay "normally" when the memory card is installed the camera reverts back to the memory card from the internal memory. Two things might be happening here one the internal memory needs to be downloaded to the memory card then saved to the computer and the internal memory card formatted. then the memory card formatted to clear those pictures. And or there is a setting switch in menu or set up that you need to manually switch from internal memory to memory card.
I know when I read this over it made scents so you might need to read it a few times to get the idea of what I'm telling you needs to be done
Apr 19, 2011 | Fuji FinePix S5700 Digital Camera
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
Kodak Easy Share z740 won't format Kodak Memory
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button.
  5. Follow the prompts to format the memory card.
Retrieved from www.kodak.com.
Mar 29, 2010 | Cameras
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
Nokia 6600 will switch off on it own pls give me the soln
Its can be happen because of virus
what u need to do is
1. fitst note down or take a backup someware of your contact no.
2. remove memory card.
3. then make format to your cell phone by pressing *#7370# then ok then put lock code (Default is 12345) then ok now ur phone is formated and back to factory setting.
4. now format your memory card with the help of pc (drive formating)
now ur cell phone is free from virus and it will not restart again
enjoy
Feb 10, 2009 | Nokia 6600
When i turn myolympus d-545 zoom on it reads card full. Then when i try and look at the pics to delet some nothing happens.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
Aug 12, 2008 | Olympus Cameras
Crappy nokia n70
To format a memory card on the N70:
Menu/Tools/Memory card,open it, Options, scroll down to Format memory card.
May 23, 2008 | Nokia N70 Cellular Phone
HP Photosmart M525 Digital Camera Logo
161 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
