Question about Sharp AL 1631 Copier
Have a new toner on and now I get a L & 1 flashing, how do I fix that
    Scholar:
  • 95 Answers
There is a lock on the underside of the top part where you get your copies out that is for locking the scanner during transport. Make sure it is in the unlocked position. I usually remove those as it causes a lot of porblems when people reach in to remove a copy and hit it accidentally!
Posted on Sep 23, 2009
What causes a dirty background?
Copied
1) - Power ON printer while holding both the + & - buttons until "OKIUSER" message appears in LCD.
2) - Press + or - button until "ENGINE DIAG MODE" is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or - button until "NV-RAM INITIAL" is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Jun 10, 2014 | OKI C9600hdn Laser Printer
MY TOSHIBA E-STUDIO 452 HAS A MESSAGE OF INSTALL NEW TONER AND I HAVE INSTALL A NEW TONER ALREADY
Step 1:- Switch off the machine
Step 2:- Press 0 & 5 simultaneously
Step 3:- Switch on machine.
Step 4:- The display shows test mode.
Step 5:- enter code 200
Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display.
Step 7:- Now switch off & on and check the problem should be
resolved. If problem continues then maybe, changing your
developer may solve the issue.
May 18, 2012 | Toshiba E-Studio 3511 Color Copier
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Just changed TONER & it still flashes NEED TONER.
have you removed the plastic strip from the toner which secures your toner.
Feb 17, 2010 | HP LaserJet 1320 Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Jun 07, 2008 | OKI C3400n Laser Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
