Question about Kenmore Elite 45986 Front Load Washer
My kenmore elite stops and flashes F06....What does that mean?
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Error code F06. what does this mean?
Whirlpool (Kenmore) 'F06' states 'tachometer failure, no motor movement detected'.
Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 12, 2011 | Kenmore Elite 45986 Front Load Washer
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Sep 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite is giving me F06 error. Any
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite 3 that flashes f06
"F06" is a Motor Speed error code. This could indicate a problem with the drive motor, motor control unit (MCU), interconnecting wiring, or the tachometer (part of the MCU). The following link explains:
I would begin by checking all the wiring and connector plugs between the MCU and drive motor. Vibration from the washer can cause the connectors to come loose. Also check them for any signs of corrosion that may be causing poor contact.
Measure the motor windings to see if they are still within specs. Bad motor windings could generate the error code as well.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
41 people viewed this question
fordexpert
Mike Squire
Robert Rankin
