Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
I have had a belkin 54g router for a couple of years and never security encoded the router before. Yesterday, I went on the web site and set up the encryption, but the keyword I thought I put in won' unlock the network. Is there a way to remove the WAP security so I can get online to attempt to set up the WAP security again.
    Sergeant:
    Champion:
  • 310 Answers
The only way to do that is to go back and remove it the same way you put it back in.. else .. reset the device so it gets back to factory defaults. you will have to set it back up from square 1 again
Thanks
Ranjit
Posted on Sep 24, 2009
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Looking to set up security for belkin 54g wirelrss router
Hello Ames3pack
Just with your windows firewall, or antivirus program, can do the trick. but if you have the router manual better, ! then you can go inside the box with the IP and set up things!
Carl
Jan 18, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How can I lock my belkin 54g router
1. Type http://1912.168.2.1 in your browser This gets you into the router's configuration
2.Look for the tab that says wireless settings or something similar
3. Look for security tab
4. Secure the router using one of the security schemes provided...whatever you use remember and write it down somewhere or you will have to reset your router if you forget your password and want to make changes to the router's configuration.
Dec 23, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Hi i have been trying to set a password for my belkin router but cannot log on line to the ip address
The address fro your Belkin 54G wireless router setup should be: http://192.168.2.1/
I would bypass the WiFi link/security and connect your PC/Laptop to be used for configuring the router via the Ethernet cable connection plug in Port 1 of the router.
If you do not have the password, you will need to reset the router to 'factory default' by using a small reset button on the back: you need a pen to push it down. Hold it down for about 10 seconds and it will put the router to factory default settings.
You will then need to reconfigure the router using the Belkins setup CD that came with the router (or download it before hand from Belkins support site): this will normally set it up automatically for you.
Hope it helps!
Dec 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Got belkin g router and dont have thye net key as
There should be a reset button on the back. This will take it back to factory settings without net key. Go to belkin web site and look for support search to see how to reset your model.
Aug 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I turn off the wireless security on a Belkin 54g modem
Jul 19, 2009 | Computers & Internet
Belkin 54g Wireless connection problem.
This is more of an explanation then a solution, but to best explain what to do I have to first explain why this is happening. When you add security to a wireless router or ap you add extra envelopes to the packets of info being transferred, adding encryption to that makes it much slower because the ap has to encode all packets coming to you and un-encode all packets being sent to the Internet. In our time this happens very quickly, but in computer time I just described a lifetime. In addition if your signal is not 100% you might have packet loss "more slow down". Now the answer, in your ap setup pages you can setup wireless security, set this to Mac address authenication and add the mac addresses of all the network cards that have access to this ap. This is by far the fastest methiod of secure data transfer.
Hope this was some help...
Tim
Mar 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router
you may need to set up a security item...can't remember what it is, but you need to set up a password as well, to make the network secure
Jan 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
176 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
