Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
I need to remove a broken heating element from my Whirlpool dishwasher and install the replacement part. I was hoping it would just "pop" out and the new piece would push in, however, it seems that it is not that simple. I need instructions.
  • jenchesh Sep 30, 2009
    This was very helpful. Thank you very much.
  • 3,741 Answers
Depend on how the heating element goes through the tub you do have to go underneath (if it goes down through the tub in the front) or even remove the dishwasher from the cabinet (if it does it on the back of the dishwasher). The tub is made of plastic. The heating element is shaped nearly like a horse shoe. The connections are in the back half on the bottom of the tub. you do have to remove the dishwasher from the cabinet unless your arms are long enough to reach the nuts, secured the heating element. ----------- Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Both terminals are secured in place with a lock nut. You can use a crescent wrench or a pair of pliers to losen, and then remove each lock nut. Reach into the dishwasher and lift the element out. Discard it. Situate your new heating element in place of the old one. Slip the terminals through the holes in the base of the dishwasher. Replace each of the lock nuts. Use a crescent wrench or a pair of pliers to tighten them in place. Now reattach each of the wires - remember, you labeled them earlier so you'd know which one leads to which terminal. Put the lower kick plate panel back in place. If you removed a heating element cover, replace it now. Replace the dish rack, and close the dishwasher door. Restore power to your dishwasher.
you can get new replacement heating element form
www.repairclinic.com
this will help.please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on Sep 30, 2009
    Sergeant:
    Novelist:
  • 198 Answers
Here's where you can download the service manual for whirlpool dishwasher:
http://www.servicematters.com/narso/tech_ref_eng/europe/service_manuals/dish/8542%20955%2010310.pdf
hope this helps.
Posted on Sep 23, 2009
How to change dishwasher heating element
Remove the dishwasher from the cabinet after disconnecting the water,power and drain. turn upside down to access the nuts that hold the element in. also replace the gaskets on the element or it will leak.
Mar 29, 2014 | Whirlpool Dishwashers
My whirlpool ADG 7540 dishwasher is not heating the water but is running through the programme
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
The
usually means u need service if u got your manual see if it mentions it, try to flip the breaker or power to it maybe it willl resets..... if u can find the tech sheet or wiring diagram on the unit maybe below behind kick panels somwhwere it might mention it,,,,,, i beleive sometimes that means ur heating element as gone out on some models,,, also some had 5 year part warrranties on the heating element... do not remove once u do u must replace that element.....hope this helps
Jan 31, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
HOW TO REPLACE HEATING ELEMENT
Turn off the electric panel breaker that powers the unit! Check to make certain it is off before proceeding.
You will need to disconnect the Dishwasher (DW) from the electric, water and drain lines and remove it from under the counter in order to be able to access the underside of the DW. There you will find two (2) wires connected to the heating element along with a couple of fasteners that hold it in place. Also check inside the DW for any hold down clamps, etc. on the heating element there.
Once you have removed the connectors and mounting screws, you can then remove the element from the inside of the DW. You will need to "pop" out the grommets that the element passes through from the inside to the underside of the DW, as these keep water from leaking past the elements. Just remove and save those grommets and reinstall them onto the new element and slip it back inside the DW and through the holes in the floor of the unit. Reconnect the wires and re-fasten the screws or clamps that hold the element in place and reinstall the DW back under the counter, reconnecting the water and drain lines and the electric power.
This is a fairly simple and money saving repair for the DIY'er and well worth the time it will take you to perform the replacement. Good luck and hope this helps. Here's a link to the versions of your DW that will show you what it looks like for the parts and placement for your specific unit as I couldn't locate an exact match without the rest of the model number series. Just select yours and look at the diagrams to find the heating element on the inside of the wash tub.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GU980SCG&pop=flush
Jul 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
How to replace a heating element on a Whirlpool dishwasher
remove kick plate, look inside the tube to see where the element goes thru the tube. there are two plastic nuts, turn off power, disconnect wire terminals, remove nuts, pull old element thru inner tube, relace in reverse order.
Mar 12, 2009 | Whirlpool GU1200XTLS Stainless Steel...
How complicated is it to replace the heating element in the whirlpool gu1500xtls1 Dishwasher? It is not drying. Can the element be replaced from inside the unit or does it does the whole dw have to be...
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Feb 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool GU1200XTLS Stainless Steel...
How do u replace heating element in whirlpool elec mod# le7010xs
there are 2 screws in the top under the lint filter remove them then with a flat head screw driver pop the lid up at the front then you should see the top of the element and there is 1 screw holding it in remove that screw then remove the back panel remove the wires and label them and lift slightly up and slide the element hosing out
Nov 11, 2008 | Whirlpool Dryers
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
155 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
