Question about Husqvarna Viking 1
Machine sewing backwards only - Husqvarna Viking 1
    Novelist:
  • Husqvarna Expert
  • 371 Answers
If you machine was recently serviced, the service tech might have reversed the motor connections. If not, it could be the zero feeding mechanism is stuck. Try dropping your feeddogs, i.e. like sewing on a button. Then raise your feeddogs to see if the problem clears. What happens when you sew a buttonhole using the automated buttonhole accessory? If these do not work, it may be your pc board which has a 5 year warranty if you are the original purchaser from an authorized Husqvarna Viking dealer. If resetting feeddogs does not clear the problem, Will probably need service by an authorized Husqvarna Viking dealer. If the service tech cannot repair, they can send to Husqvarna Viking Service Technician for repair. Visit the Husqvarna Viking website for a list of dealers closest to you. http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 25, 2009
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
6260 janome sewing machine will not pick up thread?
Needle damaged, in backwards, wrong needle, needle not fully up in the needle clamp; bobbin in backwards or wrong and/or machine out of time. User error is far more common than timing problems.
May 07, 2014 | Brother CS-8150 Computerized Sewing...
SINGER 132K6 sewing backwards only
Yes the wiring is backwards so the motor runs the opposite way.
May 18, 2013 | Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Backwards sewing machine
since the machine has been in storage for a few years, it probably needs to be serviced. oil & grease that are used in a sewing machine can become yecky & may be causing the machine to sew backwards or
the machine could have a loose or broken part. only a sewing machine shop can tell for sure.
Apr 16, 2012 | Janome Sewing Machines
Sewing machine sewing backwards??? help
reverse cam might be gunked up with old grease
Dec 10, 2009 | Singer Sewing Machines
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Only sews backwards
You probably have it in the buttonhole stitch.
Mar 23, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Sewing Machines Logo
449 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
