Question about Epson Stylus C66 Inkjet Printer
I recently replaced an ink cartridge on my Epson stylus C66 and now the ink light and paper light are flashing on and off in turn and I can't get the printer to work. Do you know if there's an easy way to fix this? Thanks, Amy
  • 95 Answers
Yes, this means that the ink waste counter is already in its peak and you need to reset it. try to download the inkpad reset utility through your computer. you will know all of the details from there on once you read them.
it would be www.epson.com/ipr
Posted on Sep 23, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Flashing ink and paper lights
Bend a strong wire a hook it out of the left side until your are able to tough it with your hand. Then push towards the right where it should be parked. Good luck.
Jan 10, 2010 | Epson Stylus C66 Photo InkJet Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
My Stylus C66 won't work.
You have to replace all ink cartridges, it is somekind selling trick. I have epson printer too and it wont work if you replace just one ink, and i have 6 ink cartridges :D
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson c66
Turn the printer off. Open up the cover and check for any obstructions inside the printer. Double check if the ink cartridges are properly plugged in and the tray cover is closed. Turn the printer back on. If you still see the error message, it means that you are having a hardware issue. Then try to contact Epson Technical Support.
United States
Phone Number: (562)276-7525
Hours: Mon.- Fri. 6AM-8PM (PT)
Sat. 7AM-4PM (PT)
Canada
Phone Number: (905)709-2567
Hours: Mon.- Fri. 6AM-6PM (PT)
Jan 30, 2008 | Epson Stylus C66 Inkjet Printer
C66 Inkjet Printer
If you have tried new cartridges and many cleaning cycles with no change, then it would be best to just replace the unit. Contact Epson as they may be able to offer you a good price on a replacement unit.
Apr 02, 2007 | Epson Stylus C66 InkJet Photo Printer
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Inkjet Printer Logo
255 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
