DVD player won't open. DVD inside
DVD player won't open, or load. DVD inside
    Problem Solver:
  • 3 Answers
On my DVD player, the cover on the disk tray was setting too high. I removed the cover, cleaned the glue off and reset it. This time it was flush with the tray. It now opens and closes just fine.
Another possible solution is to unplug and replug-in player. You still may have to do this after using my first solution.
Note: My DVD player also starts showing "hello"
Note: This solution was also listed under "dvd wont work"
Posted on Sep 23, 2009
DVD player not working!
The player uses a laser to check for a DVD. If the laser fails, the player acts like there is no DVD loaded and opens the disc tray so a DVD can be inserted. Sounds like a bad laser.
May 04, 2015 | Televison & Video
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Dvr 231 won't load
Someone needs to open the unit to see if something that does not belong got inside and to see if mechanism is functioning or not. If it does not fully load the disc it will eject it on its own.
May 28, 2012 | Pioneer DVR-231 DVD Recorder
Samsung blu ray player, dvd drawer will not open
Either the loading belt or loading gear wheels have the trouble. Sometimes the disc loading mechanism might need replacement. It won't cost mor for the mechanism. But will feel some difficulty in getting it from open electronic spare part market. it will be best to contact the authorised service center for Samsung to get it repaired.
May 12, 2012 | Samsung BDD5500 Bluray 3D Player
Samsung dvd player was working fine but now it won't load discs. What do I need to do?
If it will not accept or physically load a disc it is a mechanism problem in the unit and someone needs to open the unit to see that nothing is inside blocking the mechanism.
A lot of the players if not expensive units are cheaper to replace than repair.
May 02, 2012 | Samsung Televison & Video
Open-cloesh problems
Hello
Check its loading belt and loading motor. If loading belt get loose or loading motor has low pulling power [due to trouble with its carbon brushes inside it], this type of problem will occur. There is a gear wheel assembly inside it which draws in and pushes out the tray mechanism. If any of these wheels gets broken, the mechanism won't work properly, even if the loading motor and loading belt is right. If so, replace the loading mechanism. It won't cost more, and can be bought from most of the electronic spare part shops at your town. OK.
Aug 12, 2011 | Televison & Video
I bought a LC DVD 199A in November for a Christmas present. Until today, I have not tried to used the DVD player because I haven't really had a chance. I put the source mode to DVD but the DVD...
The DVD player has a problem with the loading mechanism. Probably something has dropped inside it such as a coin or something else. It is really a simple problem. The reason why it would switch back to TV is because it is getting stucked. Get a flashlight and see if it has foriegn ofbect inside the slot. If you can remove it somehow it is the best way to fix it. I don't recommend opening the device.
May 24, 2011 | Curtis Televison & Video
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
Electro Med Services...
