Question about HP OfficeJet 6110 All-In-One InkJet Printer
I needto download the instalation package file *.msi if possible. I have had my printer for some time. I am having a problem scanning documents and the hp area is asking for this file hp officejet 6110
  • albutler Sep 23, 2009
    I do not want to lose all the other features. The printer is working fine with it's other features.
    Like I aked you is there another way to get the software I need without uninstalling everything right now.
  • 4,281 Answers
Ok
First uninstall hp driver and software from computer then downlaod installation from below link then install.
You uninstall any software from start menu->control panel ->add remove program.
And for uninstall driver press windows key + pause break key then you see system property then go to hardware ->device manager.Then right click on driver then you can uninstall.
click here
select your operating system and downlaod driver and software for your printer.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 23, 2009
  • ok for that downlaod this driver and software then install it in computer without uninstall.
    Then it ask for repair option so select repair then it works fine.
    Thanks.
I can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
Jun 23, 2011 | HP Scanjet G2710 Flatbed Scanner
''Error 1706''
My colleague says that when Error 1706 occurs during an attempt to install an MSI file from removable media, the first thing you should try to do is check the Media Package Pathway and determine if the pathway does in fact track to the right folder. If it does not, scan the removable media and locate the file where the MSI file is housed. In some cases, you may find that the MSI file is found in a folder that is named App1. Once you have determined where to find the right file, it is a matter of resetting the Media Package Pathway so that the system will find and activate the MSI file. This will require you to make some changes to the command line or possibly make a permanent change in the registry.
It is important to note that making changes in the command line and especially in the registry are functions that someone who is familiar with writing code and general information system functions should perform.
If you are not knowledgeable about these sorts of functions, there is every possibility that the modification will not result in resolving the issue regarding the MSI file. Further, the change may create additional problems with the media package.
May 28, 2010 | Computers & Internet
UNABLE TO MAKE CORRECTIONS TO DOCUMENT
Scanners put a graphic image on your computer that is a "picture" as far as the computer is concerned and therefore, you cannot edit text because it is seen as pixels and not characters. In order to make a scanned document editable, you'll need to use the OCR function in your software (Optical Character Recognition). This is assuming your printer came with OCR software, if not, you'll need to purchase an OCR software package in order to convert images into editable documents. You should be able to find such packages for less than $50.00. Check your documentation (and help files) and look for OCR in the index or search the help files for OCR to see if such software came with your printer software package.
Jan 30, 2010 | HP Photosmart C4240 All-In-One InkJet...
HP Guru Needed!!! Subsystem spooler printer errors, trayapp.msi and HP Photosmart Essential.msi errors.
Best solution is to download the latest AIO software package from the HP site and install with that. Just make sure you get the right package (32-bit or 64-bit).
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Everytime I try to download certain software that uses MSI, I get this message. "Windows has the following information about this file type. This page will help you find software needed to open your
Hi Princess Tina,
It sounds like the registry keys needed to recognise and open msi files are missing or incorrect.
Paste the following into a new file (eg. with notepad) and save the file with a .reg extension. setupmsi.reg will do ok. Then double click on the saved reg file and add the keys to your registry. (The first line "Windows Registry Editor Version 5.0" must be the first line in the file).
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.msi]
@="Msi.Package"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package]
"EditFlags"=hex:00,00,10,00
"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\
00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
32,00,5c,00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,34,\
00,00,00
@="Windows Installer Package"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\DefaultIcon]
@="C:\\WINDOWS\\System32\\msiexec.exe,0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell]
@="Open,Repair,Uninstall"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Open]
@="&Install"
"MUIVerb"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\
6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,36,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Open\command]
@=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
73,00,69,00,65,00,78,00,65,00,63,00,2e,00,65,00,78,00,65,00,22,00,20,00,2f,\
00,69,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Repair]
@="Re&pair"
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,37,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Repair\command]
00,66,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Uninstall]
@="&Uninstall"
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,38,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Uninstall\command]
00,78,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
Good Luck and don't forget to leave a rating,
Thanks Mark
Apr 23, 2009 | Computers & Internet
Can't save my scans in pdf form
This can possibly solve your problem:
0. you should have the CD that came along with the printer. the solution that is listed below is working for windows xp operating system.
1. Browse the CD -> Go to the Setup folder. -> Go to the DocProc folder. -> Double-click Docproc.msi to install. you will not see any progress etc.,
2. Browse the CD -> Go to the Setup folder. -> Go to Qfolder . -> Double-click Qfolder.msi to install. same as above.
3. Go back to your HP solution centre and under scan settings option you shhould get to see the PDF options (and a few others as well).
cheers
Apr 14, 2009 | HP DeskJet F4280 All In One Printer InkJet
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Scan
Uninstall it!Then while u install it change the directory dont install on programs files simply create new folder then install there...
Feb 29, 2008 | HP LaserJet 2840 Printer
Scanning to acrobat 6
Insert the CD you got with the product to the drive. Search for scan.msi. If you can?t find it you can get the file and instructions on how to install it on HP?s site - http://h20000.www2.hp.com/bizsupport/TechSupport /Document.jsp?lang=en&cc=us&objectID=c00063888
Feb 21, 2006 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
