Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
We have had our TV since January 2006. Just in the past month it turns off by itself. We can turn it back on, but at the next commercial it turns off again. The weird thing is sometimes it can go an entire day without turning off, other times it turns off after the first 20 minutes and keeps turning off.
  • 10,594 Answers
If it is Sony KDF-42WE655 model then it sounds TV needs lamp.
Have you replaced its lamp since 2006?
And please check when TV gets off itself, does its standby red light blinks? if yes, how many times it blinks? This is an error code.
Let me know to find out any possible solution.
Thanks.
Posted on Sep 23, 2009
Sanyo tv turns itself off
Power supply failure
Jan 29, 2014 | Televison & Video
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
The tv turns itself off constantly usually sfter 7PM and mostly when commercials come on, iturn it back on, then it goes off at the next commercial. sometimes stays on for hours without going off, then it...
your tv off own its own, because its regulation varies, the voltages changes at the output of your power supply, take your tv for repair immediately before it burns more components outside the supply. ask your technician to connect a avo meter at the output of a supply and observe for along time, he will notice a change. thanks
Mar 27, 2009 | Sony 32IN TV Stand Designed for Model...
Our TV shuts off by itself usually during commercials. We have to unplug it, plug it back in and turn it on manually ~ till next commercial. Seems to happen more on the cable channels ~ the main networks...
Since commercials are louder volume-wise (especially with cable more than satellite), my first guess would be that you have a faulty part around the audio amplifier of the TV, and it loads the power supply or creates a high/low that tells the TV micro to turn off. Knowing what brand the TV is helps, but in any case, it probably needs to be referred to a TV repair shop for tracking the part(s) down.
I hope this helps you...
Jan 08, 2009 | Televison & Video
Flashes orange 2 times every 5 seconds
There is a 20 pin cable that goes from the main board to the light engine that can cause this issue. The other possibility is the door switch or the cable that leads to it has failed. If none of those correct it then the light engine itself is the problem. Hopefully one of the earlier mentioned items is the issue as the light engine is costly. The part number for the cable is LSJA0467 and is available here http://www.partstore.com/PartNumberSearchResults.aspx?PartNumber=LSJA0467
Mar 26, 2007 | Panasonic PT-43LC14 Television
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
