Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
Problem for Whirlwind -Air Cooler with Heater and Humidifier, FH-778...
Unit in basement leaking around bottom
By bishrdb on Sep 23, 2009
unit has a pump to remove the moisture but is leaking at bottom where the unit is sealed with duct tape
Solution #1
posted on Sep 24, 2009
Not Rated)
FNGHVAC
Rank: Master
Rating: 82%, 6 votes
It sounds like a blocked evap. pan. If you have access to the drain line like a tee in the condensate line, you can blow it out with nitrogen or co2. If you cannot access your condensate line, you will have to remove the access panel on your indoor coil. remove the tape and unscrew the panel door be carefull not to upset the copper lines running into the door. Good luck.
Was this helpful?
Yes
No
Solution #2
Not Rated)
meBNme
Rank: Guru
Rating: 92%, 182 votes
The drain line coming from the internal drain pan to the pump is clogged, causing overflow of the internal pan. That means the water never reaches the pump, and is simply overflowing into the bottom of the unit/duct.
The drain line and pan need to be cleaned and cleared.
A shop vac is a wonderful tool for such a job.
Was this helpful?
Yes
No
Popular Solutions for Whirlwind -Air Cooler with
Questions and Unsolved Problems for Whirlwind -Air Cooler with
Do you recommend Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner?
Answer
Answer
My thermostat is saying that the system is on, but the heat will not kick on. I have gas heat, any... (More)
Answer
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it... (More)
Answer
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
