Question about Dell Wireless Keyboard Optical Mouse w0147
Problem of keyboard keys getting transposed.
I bought a dell pc ,some months back and it was working absolutely fine .But now the keyboard has started giving some problems like when i press the ('')inverted comma key ,@ symbol appears on the screen and vice versa. the same problem is there for many more keys too.
It would be kind of you if you could suggest a solution for this.
Mrinmoy
    President:
  • 2,666 Answers
Your region and language settings are incorrect.
Go to control palel/Regional&Language settings/ use the drop down menu to select the correct region then click on languages tab/details and do the samme. apply and exit.
Posted on Sep 23, 2009
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
Tip
Tips on Repairing Laptop Keyboard Keys
When you go shopping for a laptop keyboard replacement, it is good to use a parts locator tool. This type of tool makes users to enter their laptop's model number to see exactly what replacement parts are available for it. This ensures compatibility and avoids the hassle of returns and exchanges. The most amazing thing you are going to get is the Dell keyboard. There are several various ways you can repair a damaged laptop keyboard as long as you know what the problem is. Now, there is a step-by-step guide for you how to make your Laptop keyboard, like Dell keyboard work well as it did when you first bought your laptop.
Tip1: The Easiest Way to Fix the Keys
Buy a can of compressed air and spray it on the keyboard if your keys are sticking together. This is the easiest thing you can do to fix the keys on your keyboard. It doesn’t work for all problems, but it’s a good place to start. Make sure you get the air down inside the keys to clean out any debris, hair or food that may have gotten caught in there.
Tip2: Replace a New Keyboard
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
Tip3: Solve Fall Off Keys
Use a small dab of super glue to replace keys that have fallen off. Dell laptops often have keys that fall off, especially as the computer ages or is used quite frequently. Place a small dab of glue directly on the round part that holds the key in place and lightly press the key down. When the glue dries, you’ll be able to use your laptop again.
Tip4: About the Retainer
Remove any problem keys from your keyboard and look at the plastic retainers. At times these retainers can become broken, damaged or simply fall off. Carefully pull off the retainer, clean it off with some compressed air and snap it back into place. Then put the key back into the slot and everything should work fine.
Buy Compatible brands Laptop Keyboard from Papatek.com, who offers Compatible all brands Keyboard wholesale, like Dell, Acer, etc with best price, 6 month warranty, and shipped fast from USA!
on Aug 16, 2010 | Computers & Internet
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Brand New Axiom 25 most keys do not play
use on screen keyboard and type your keys if this work then it is hardware problem if not then it is a virus scan it
Mar 27, 2010 | M-Audio US85100 Keyboard
Dell ke board : the button between the t and u stopped working. wh ? tried pulling button off and pressing underneath but still won't work.
try a diffrent key board and check the "y" key on it if it works try sending the keyboard in to get a new on or take the keyboard back to the store you bought the pc from you can get a new keyboard fairly cheap from http://www.newegg.com/Store/SubCategory.aspx?SubCategory=63&name=Keyboards
good luck
Feb 24, 2010 | Dell Inspiron 530 Desktop Computer
Keyboard problem in Dell Latitude PPX C Family
Actually this is a common problem with these Dell's. I have never found a cure for it other than replacing the keyboard. Fortunally they are not expensive, you can usually get one off of eBay for around $20 or so.
Hope this helps
May 01, 2009 | Dell Latitude C400 Notebook
Transpose feature on the Roland RD-600 digital piano
If you want to play in C and carry the sound of Bb,
1. From C, count down two half-steps to Bb
2. Press and hold the Transpose button and press the key on the keyboard that displays through the window, "-2"
3. To turn off the transpose feature, just press the Transpose button again.
Feb 23, 2009 | Roland Vs-2000CD Digital Studio...
Keyboard not working
Hi abcd_21 ,
You have a dell machine, therefore ...
Run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system.
GoodLuck :-)
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
Keyboard doesn't work
Ok, well it is probalby going to be one of two things. and seeing that you did not mentin that the computer dose not start up and boot fully then I am going to narrow it down to one. Chances are she broke the keyboard or shook the cable loose. when you have time and internet access to be able to talk to me on here and have me walk you through removing the keyboard to check it let me know. I am able to talk with you 24/7 just give me a couple of hours of notice so I can keep my attention on your situation.
Apr 28, 2008 | Dell Latitude D600 Notebook
Dell Wireless Keyboard Optical Mouse w0147 Logo
244 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
