Question about Sunterra 3000 GPH Pond Pump 203000
I have a 4300 GPH Pump It got left on out side of
I have a 4300 GPH Pump It got left on out side of the pond and is making a load noise. Like to is jammed up can I repair this or send it in for service???
    Problem Solver:
  • 7 Answers
Most likeluy it overheated wile running outside of the water. It neds the water for cooling.
You might need to buy a new one
Posted on Sep 27, 2009
Making humming noise, but not pumping water
Are trying to run a 50 hertz motor on a 60 hertz line?
Sep 03, 2013 | Pondmaster In-Pond Filter System Kit -...
I need to find the total amperage used by an Alpine Hurricane 2100 GPH Pump. We're wiring for our pond, above ground pool pump, and some lighting and want to get the correct size wire.
The pump is 125 watt so takes about 1 amp at 10 volts or 0.5 amps at 230 volt. You should be ok with using 1.5 square millimeter NYMJ wire. If the wire is liable to be damaged you may need to use armoured cable. If you are in the US and are more familiar with wire gauge sizes I can look up the equivalent wire size for you.
Jul 19, 2011 | Hurricane Alpine Waterfall Pump 2100 Gph...
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Mag 7 pump does not work
prime pump till over flows connect lines make sure no leaks pump has low or no water shutoff built in make sure intake is completly submerged at all times, hit reset switch
May 09, 2010 | Pondmaster Pond - Mag 7 Pump, 700 Gph
Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Apr 17, 2010 | Tsurumi Pump s Submersible Trash Pump -...
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
Ecoplus 230 surface pump plugged. Is there a filter or debris screen to clean? pump is primed. runs without excess noise. no water out the outlet port
Hi ! Nothing to clean on this, just make it pump some hydroponics cleaning pump products with distilled water to remove the deposit without taking risk to damage your system/plants. Thanks and have a nice day J -
Oct 24, 2009 | National EcoPlus 100 GPH Submersible Water...
Shaft fell out of Pondmaster 700 Gph pump.
DANNER MANUFACTURING, INC. 160 Oval Drive Islandia, N.Y. 11749-1489 Phone: (631) 234-5261 Fax: (631) 234-4778 e-mail: Sales@dannermfg.com
May 06, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Filter
You can build your own little filter by placing is in a container, like yorgart, with lid, but before you do punch holes into it no more than 1/8 inch all around. the more holes the better. this way your pump does not **** something into the chamber that will stop the propeller. I have done this and it works like a charm. Also you can use pond pots, the ones that have many slits in them.
Magnetic Drive Pond pumps can be left in the pond even if it froze. These pumps are great for weather. Once water unfreezes, pump will start again.
Jan 04, 2009 | Sti Group Sti Infinity 160 Gph Magnetic...
Sunterra 3000 GPH Pond Pump 203000 Logo
196 people viewed this question
Top Sunterra Garden Experts
Dennis Key
Dennis Key
john h
Are you a Sunterra Garden Expert? Answer questions, earn points and help others
