Question about Kenmore Washing Machines
I have a top-load washer that began leaking at the front of the unit. The water is dripping from the front-center of the machine. It begins leaking immediately upon filling and will continue to leak for several hours after stopping the fill cycle and pumping all the water out in spin cycle. I have checked the hoses, both supply and drain, and there is no leaks at the back of the washer. HELP
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the area for the motor and pump.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Posted on Sep 23, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
Elite 45986 Front Load Washer: My 2002 Kenmore elite front load washer (stackable...
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 27841 Top Load Washer has developed a water leak
Hi, Check the pump. Tip the washer back after the load finishes and see if the pump is dripping. The pump is located on the front side of the motor. If the leek seem to be in the front center of the washer, it is probably the pump. I hope this helps. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Leak
bad pump..take some news paper and slide in from bottom you will notice that the drip is coming from the left side more,,..if you can get behind unit theres 2 green clips on the right and the left remove these,,if you cant get behind remove front panel ..and remove from front...slide lid forward than remove lid switch connection right front corner,,now the tops off...remove the 2 screws holding washer front panel..now your in ,,to put back reverse...att'' always unplug unit first
Sep 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Jul 05, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
67 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
