Question about HP LaserJet 4350 Printer
4350d prints 2 pages for every 1 page received
    President:
  • 2,049 Answers
Your Printer Preferances is probably set to 2... solution is
Go into Control Panel > Printers > right click on the 4350 and choose Properties.
Look for Printing Preferances button near the bottom and click it.
Choose the Advanced tab and make sure Copy Count is set to 1
Posted on Sep 23, 2009
I have a printer thats printing on one side only. how can i fix this
Do you mean double sided printing? If so this model printer does not have a duplex unit and cannot print double sided prints automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will beprinted on the other side of the page 1).
Repeat this procedure for the other pages.
Jun 15, 2012 | Brother Office Equipment & Supplies
Tip
Printing Sections in Microsoft Word
Printing Word Documents with Multiple Sections You have a document with multiple sections. When you try to print specific pages, you get either one single page, or the whole document. What you don’t get is the two separate pages you need.
First, take note of which section has the first page you want to print, and in which section the second page resides.
You need to print Page 2 of Section 1 and Page 1 of Section two.
In this particular case, the command is the usual: File | Print:
The difference in this case is how you specify the pages to be printed. In the Pages dialog box, type P2S1, P1S2 and then click OK. The comma “,” separating the two pages indicates two separate pages. The result will print Page 2 of Section 1 and Page 1 of Section 2.
If, however, you wanted to print from Page 2 of Section 1 through and including Page 1 of Section 2, the command would be P2S1-P1S2. The dash "-" indicates a range of pages, which results in printing from Page 2 of Section 1 through and including Page 1 of Section 2.
on Mar 26, 2010 | Microsoft Word 2003 for PC
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
Message
you need to print this fax out of memory.
1 Press [FAX], then press [Menu].
2 Use [ ] or [ ] to select <MEMORY REFERENCE>.
3 Press [OK].
4 Use [ ] or [ ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>.
If you select <PRINT DOCUMENT>:
1. Press [OK].
2. Use [ ] or [ ] to select the transaction number (TX/RX NO.) of the document you
want to print, or enter the number using the Numeric Keys.
If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See page 94.)
3. Press [OK].
4. Press [ ] to print the first page only, or press [ ] to print all pages of the
document.
5. To print another document, return to branch-step 2, or to finish printing, go to step
Oct 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Having trouble printing a document file in word
Check page setup and ensure page size for document same as page size for printer.
Check printer not set to only print current page.
Feb 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP LaserJet 4350 Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
