Question about Oster 4724 Rice Cooker
Will not turn on
My rice cooker will not turn on. The electrical outlets work with other things plugged in. The cord doesn't appear to be damaged. The switch clicks when it's pressed down. What could be wrong?
  • 8 more comments
  • koroba Jan 02, 2008
    I also have this identical problem. It is only the second time I have used this appliance and now this. I have set up to cook rice and all components are in good shape and I have the electrical cord double-checked for connection and power to the outlet. But..no cooking light and the unit is not heating.
  • Anonymous Feb 14, 2008
    yup same problem here
  • maurice tom Mar 23, 2008
    I think your rice cooker has a thermal switch (or thermal fuse) that is open.It is very easy to fix it.It cost me less than 2 bucks to replace it.To check it ,use an ohmeterter .Unplug your cooker ,put two probes to the prongs of the power cord to check for resistance,if the meter shows infinite resistance=your themal switch may be open.Now open the bottom of the cooker ,find the wire that goes to the side of the intrument,pull it out and you will find the thermal switch ,check it with the ohmeter for continuity .if it is bad =replace it (I hope it is not the heating element)
    Maurice Tom
  • Anonymous Apr 21, 2008
    Bought Oster cooker two months ago and today will not turn on. Indicator lights are not working. What can we do?
  • fix-it-ex May 27, 2008
    I had the same problem as well. No lights -just went dead. I called Oster at 1-800-334-0759. They are replacing it for free as it is still in the 2 year warranty period. Have the code (letter+ numbers) from the prong that plugs into the wall handy.
    NR
  • kevflet Aug 24, 2008
    I have had the same problem. I have found the thermal fuses on line @ http://www.bgmicro.com/index.asp?PageAct.... I replaced mine with part # FUS1128, Thermal Fuse 184 Deg C. All is working fine now. At the time of purchase they were only $0.39 each, so I got a few extra. Hope this is helpful to someone.
  • Anonymous Oct 07, 2008
    This is the same problem i am having as well and it is very frustrating as i love my cooker and use it alot.
  • hello_avon Nov 20, 2008
    I will not turn on.
    I will try to change the fuse thanks.
  • bob3622 Jan 09, 2009
    I have had the same problem and have had Oster send me out 2 addittional units for free. the 2nd 2 i received broke faster than the first. they broke in the first 2 uses. what a shame because we really liked it. Find a new product not made by Oster...maybe they will eventually issue a recall or use better parts.!
  • fix-it-ex May 11, 2010
    where can get the thermal switch from ? Oster service senter said they do not sell those !! NR
Hmm, I can see this. But it seems to me that this is a common problem with Oster's rice cookers. I'm in product management (construction equipment) and it's obvious Oster has a wide-spread problem. If a service center is the answer (and there is none around me) then I'll dump this one and buy a different brand. Thanks
Posted on Jan 16, 2008
  • 871 Answers
Hi!
i suggest you bring this to a service center since you guys mentioned that there are no external problems, the thermal capacitor may be busted.
hope this helps.
I have an ikeda 10 cup rice cooker, it wont power on
Try it in a different outlet. Does the unit have a light that comes on when plugged in? If the light is in the cord and the light is still out on a different outlet, the cord may be faulty. If it lights, check to see that the connection between the cord and cooker is tight.
Jan 21, 2018 | Kitchen Appliances - Others
Rival 6-cup rice cooker does not work
I have had THREE different cookers over the past year and ALL THREE have done the exact same thing. It has to be electrical and I suspect it blows an internal fuse...then it is no longer working. This is awful. I would never recomend it to anyone.
Oct 25, 2012 | Rival RC61 6-Cup Rice Cooker
Hi , I've Alaska Rice cooker In Munich. Suddenly i cannot see the red light when i plug it. What should be done kindly suggest and advice asap
Try another AC cord, then plug it on the wall outlet, or plug to another good outlet, if not work, Rice cooker heater system inside problem, maybe its wiring loss connected. Bring your Unit to the nearest qualified technicians..
Aug 08, 2011 | Hitachi RD4056P 5.6-Cup Rice Cooker
When I plug in the rice cooker it doesn't turn on. What could be the problem?
Try to replace AC cord, then plug to another live wall outlet if not working, problem is inside the unit,remove to to the outlet, carefully open the bottom side check wiring connection for loss connected, or Bring your Unit to the nearest Qualified technicians.
Aug 02, 2011 | Zojirushi NS-TGC10 Rice Cooker
My rival rice cooker does not work. i plug it in and try to turn it on - the lights don't turn on and the unit apparently doesn't heat up or work at all. tried different outlet - same result. should i...
It is a blown thermal fuse. On 6-cup Rival it is across terminal where power comes into cooker. You can replace thermal fuse for less than a dollar in under an hour. Remove the bottom of the cooker. The thermal fuse is covered by a heat wrap sleeve across input terminal.
Feb 09, 2010 | Rival RC100 10-Cup Rice Cooker
There is no electricity going to my cannon classique 2000 but are electricity going to the plug
Check power cord for damage. Check Follow wires and check to see if the App itself has a fuse or Lose wire could be inside the App.
Oct 29, 2008 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Rice burning at bottom of cooker
Your cooker, along with mine, cooks very hot. If it is new then you can take it back, but if you want to cook with it then you need to stir the rice often. About every 5 minutes should be good. As soon as it is done you need to remove it from the cooker. Let's see how that works.
Aug 30, 2007 | Oster 4724 Rice Cooker
Rice cooker
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord.  make sure those two are both working good.  next step is to open the Rice Cooker Bottom.  Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective.  Which is the reason why your cooker is not turning on is due to an open in the circuitry.  Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Aug 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Oster 4724 Rice Cooker Logo
773 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Hjalmer Lamminen
Hjalmer Lamminen
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
