Question about Samsung 7.3 Cu. Ft. Electric Dryer
My dryer makes a winding noise when its turned on could this be the belt in my samsung
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Posted on Sep 29, 2010
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
vanni7
  • 163 Answers
SOURCE: dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Posted on Jan 04, 2009
marka19
  • 1430 Answers
SOURCE: replace dryer belt
Try this link http://appliancehelponline.com/dryerbeltvideo.html
Posted on Jul 23, 2010
Crosley large capacity dryer turns on,drum turns,makes humming noise...
sounds like could be bad windings on motor also check belt switch
Nov 22, 2016 | Crosley Dryers
What is the "thump" I hear when the drum turns?
If it only happens when it turns on and it's a samsung dryer, there are a few problems you may have, depending if it's on a pedestal making noise or not, it could not be level causing an uneven position of the unit to make odd noises, or if it does it with or without clothes on it, it could be the idler pully misaligned or the motor not secure enough. If it happens only for a very very short period of time after you start the load, it isn't anything serious to worry about, however, you may end up having to replace the belt down the line. If it runs quiet, I honestly wouldn't worry about it. If its making a really really loud noise during the cycle continuously, you're having a bearing problem, but I think you're just experiencing a very small wear and tear noise and a lot of dryers can do this. Pinpointing it may just not be worth your time.
Jan 31, 2015 | Samsung DV337 Electric Dryer
Why is dryer making a noise loud and sounds like motor?
U may have a bad bearing going out or the drum roller wheels or pulleys are bad. a bad belt? hopefully its not the motor or windings and brushes going out? Then agin may need to have the tranny looked if its seizing ? sorry lots of different opinions here but it could ba any of the above. is it tunrning ok or is it unbalanced and can u hear the noise from within the dryer if so it may just well be the drum rollers and thats not a difficult or costly job?
Aug 16, 2014 | Maytag Dryers
Why is my maytag dryer making a loud noise when i turn it on?
could be varied issues? bad bearing, bad drum rollers? belt? and last lets hope not bad motor bearing, windings or brushes?
Aug 16, 2014 | Dryers
When I wind the dial it makes a ticking noise but doesn't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 10, 2011 | Dryers
When I push the start button, the drum will not always turn. Sometimes it make a buzzing noise and it smells like th emotor is heating up. after a few trys it won't even try to start. I took the dryer...
Sounds like the centrifugal start switch in the motor is malfunctioning -- the motor is running on the start winding and not switching (via the centrifugal start switch) to the run winding. The smell is because the start winding is overheating.
The centrifugal start switch is inside the motor on the end of the shaft with the pulley. You should be able to see it. Give it a good cleaning and lightly lubricate it. Move it back and forth to get it moving freely while cleaning / lubricating.
If this doesn't clear up the problem, the motor winding could be shorted already or the centrifugal start switch could be damaged beyond help by cleaning / lubricating.
More info, let me know.
Charlie
Feb 08, 2011 | Maytag Dryers
Drum won't turn-belt is good-motor
If you can manually turn the drum, the motor's start windings may be bad.
If you can't get the drum to move, check to see if a sock or other small item is stuck between the drum and the inside of the front of the dryer. If you see nothing, it's possible that one or more of the four drum rollers is/are seized.
Jul 15, 2010 | LG DLE2532W Electric Dryer
My dryer makes a buzzing noise and will not turn on. I have to reach in and turn the drum, retry-go through this process several times before it "catches"and turns on iam wondering if it is the belt
Most likely it is the start winding on the motor. The buzz you are hearing is the thermal overload. You would have to replace the motor. Check pricing against a new machin. Sometimes the parts are less cost effective than a new dryer.
Dec 08, 2009 | LG DLE5932W Electric Dryer
Samsung 7.3 Cu. Ft. Electric Dryer Logo
981 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
