Lands Phones Logo
Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have added one expansion board to the mother board to enable more telephone extensions. (The manual is vague about this procedure) When I plug the ribbon cable into the mother board, the enhtire system seems to go down. I'm wondering if I have to have 2 more CO lines plugged into this expansion board to take advantabe of this expansion board features. DRK
Carl Navarro
Level 3:
  • Master 2,460 Answers
  • Posted on Sep 23, 2009
Carl Navarro
Master
Level 3:
Answers
2460
Questions
Helped
1155348
Points
7314
Yep, the manual is extremely thin when it talks about adding the expansion cards. Check that connection. You either have bent/broken pins, the cable plugged in wrong, or a bad expansion board.
The board plugs into the top port on the cabinet, but you might also try plugging it inot the bottom and see if it kills the system. If it does, I'd be leaning toward a bad board.
Carl
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
How do I connect the Norstar M7324 telephone to an expansion set?
Your expansion box is a CAP (central answer position) module. I will assume you are using the same jack as before. The line cord, from phone to jack should be 6 conductor (count pins on end). A short line cord runs from back of phone to back of CAP (plugs on CAP are labelled) then the longer cord runs from CAP to the wall jack.
Fix it my life is on hold
Most of the newer DECT 6.0 phones i have dealt with are having inherant problems on the mother board . relace it was my only option .
1helpful
Hi, I've just added and expansion card in my panasonic tes 824. but the problem is although the additional extensions are working. no additional CO lines are being detected. when i go to the CO line...
No. At the very minimum, you need to go to program 400 (3.3 in the U.S. Maintenance Console) and turn on the lines. Access may have to be enabled from each extension for both outward and ringing programming might have to be added.
Carl
1helpful
Show telephone's own ext. number
To find out what the extension is in the board room,on the board room phone press feature *0 then press one of the intercom keys. You could also call another extension from the board room phone and see what extension number is on the display of the phone being called.
Uniden dect 6.o
What model Uniden DECT 6.0 phone/answering machine?
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
