Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
When switching from 480 to 1080 my blue shifted and I can't get it back into convergence with red. I've unplugged the tv overnight to no avail
  • Akai Master
  • 8,457 Answers
Ur convergence is dead,need a convergence kit,replaced what in that kit.Know how to solder?Tries these websites.Tv Repair World.com,Ebay.com.
Posted on Oct 12, 2009
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
Picture in 3d without the 3d glasses
your convergence settings are moved and they need to be adjusted and if you adjust and still have the problem then its the problem of convergence STK ICS and they need to be replaced.
for adjusting the convergence please click this link this will help you how to adjust the red, blue and green settings in your tv.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for replacing the convergence STKics just click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
feel free for further assistance.
thanks.
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
Change element tv from 480 to 1080
The TV will play whatever signal (480,1080 etc.) it is being given, that is to say if you have 1080 available that is the resolution it will switch to, so there is not anyway to change this.
Feb 06, 2012 | Element Electronics Televison & Video
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Mitsubishi 55411 projection tv has red band across bottom
go into the customer menu and select convergence with the original remote; if either the red or blue will not move in some direction, you have a bad convergence IC(the WS-55411 uses two STK-392-110 CONVERGENCE IC chips)
Aug 12, 2009 | Televison & Video
Blue convergence is shifted right slightly
CHECK FOR THE SUFECE MOUNT CAPACITORS AT THE SMALL CONVERGENCE CIRCUIT BOARD
Jul 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Red Green Blue Across The Screen
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm · http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 06, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Yes, especially big screen. It sounds like convergence is out of lign. Try menu and straighten out, wait until set is warm first.
Dec 06, 2007 | Sony KP-46WT520 46" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
