Question about Candy CDC266 Dryer
Cic60 candy tumble dryer
How do you get into the machine to replace the heater element? Which panel must you remove if any?
  • 1 more comment
  • bobbiecool Apr 16, 2008
    I have the same dryer and there is NOT a panel at the back. So how on earth do I get in to change the element?
  • shellhill Dec 03, 2008
    I cant get to the wires to reconncect the new heater which panel needs to come off there isnt a rear panel
  • Anonymous Mar 15, 2014
    Came find how to get in machine to replace ad back don't come off
  • 833 Answers
Generally, these units are gotten into from the back panel. Be sure to disconnect the power. There are two breakers linked together.
Posted on Dec 18, 2007
How can I get access to a Candy Grand tumble dryer to change the element?
Google search Candy Grando Tumble Dryer service manual. If one is available, you can download it and find the information you seek.
Apr 30, 2015 | Candy Dryers
My candy tumble dryer gov218-80 blows just cold
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Oct 04, 2014 | Dryers
Candy cic60
your element
Mar 28, 2014 | Dryers
Hi, My candy CIC60 tumble dryer has stopped drying and the empty water light is constantly on. The timer works. I have cleaned all filter,emptied water, checked for loose wires and I can not see a problem....
Tumble dryers are really not around my neck of the woods however I have studdied them just in case they do begin to show up around here. What turns on the light and kills power to the dryer when the water tank is full? A float switch. I bet that float switch is stuck. Probably something simple like that.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2011 | Dryers
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 | Dryers
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
CIC60 01 tumble dryer only works if on/off button is held in
is the new on/off switch new or second hand if its new get it exchange cause these switchs have a spring in them with 2 channel cutouts in them once depressed when it starts to come back up it automatically goes into another channel which keeps it on faulty switch thats all it can be if secondhand again take it back cause its faulty this is the only thing it can be they are simply made so they dont mess up try doing it when its not on the washer love peter
Nov 16, 2007 | Dryers
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
327 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Marvin
Marvin
Are you a Candy Dryer Expert? Answer questions, earn points and help others
