Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a coleman powermate 6875 engine runs fine and it all works till it gets hot then the engine still runs but not charging.
  • 788 Answers
The unit should have a pop out fuse or set of fuses.
If you are drawing too much currant from the unit, it will shut down. If you plug in a simple 100Watt light and test the unit and see if it stops generating currant.
Max is only 5500.
You may also have shutoff thermo sensiors, if the caseing of the generator runs too hot or low on oil, it will shut unit down.
Keep in mind, if you have a shut off valve, turn the shut off valve, closing the fuel supply while running.
This will remove all gas from the bowl and not spoil after setting for long periods of time.
Same with oil, it will do damage to the engine if it just sets for long periods.
Posted on Oct 01, 2009
What spark plug does a Coleman Powermate 6875 use
Doesn't seem to be anything online. Phone them and ask.
Specs are here
http://salestores.com/colema21.html
Generator manual with phone number
http://www.powermate.com/generators/0062929_0706.pdf
Oct 05, 2016 | Coleman Electrical Supplies
What kind of oil do I use in the Coleman powermate 6875?
You can use numerous engine oils. 10W - 40, 30W Detergent, 30W Non detergent (SAE)
The best all around above 40 deg F and below 100 F oil to use is a 30W detergent oil. Brand name does NOT matter. Oil level should be checked EACH time you add fuel. Change oil any time the oil appears Dark BLACK when checked regardless of the hour intervals. .
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Coleman Powermate Powermate 5000W...
Need a stater kit for a powermate generator 6875
You will need to contact a Coleman dealer to purchase any parts. Fixya.com has no resources to order or sell parts for any consumer product.
Jan 30, 2011 | Coleman Powermate Generator Start &...
Coleman Powermate 6875 genset will on run with 1/2 choke
nick just take the carb apart piece by piece and pay very close attn to where the parts are coming from if you have to write it down or take pics. use a standerd carb cleaner but be sure not to spray any of the rubber or plastic parts with it. i hope you luck my friend. jd in la
Sep 17, 2009 | Coleman Powermate Powermate 5000W...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6875, Does it have an auto idle???
If you've got an auto idle function you'll also have a switch somewhere to shut it off, so look for that first.
Engine surging is almost always a problem somewhere in either the air cleaner or the carb. Check the air cleaner, if it's not dirty take the bowl off the carb and look for dirt in the bottom.
Regards,
Carl
Feb 02, 2009 | Coleman Powermate Powermate 5000W...
Add auto idle to generator
Your genny should already have this feature as it is part of the function to maintain the output voltage, if it isnt working I would look for a service manual for it and taker it from there as there can be many things that could prevent it from working properly
Dec 31, 2008 | Coleman Powermate 7,000 Watt 13 Hp...
Wont turn over
Check the oil level, these generators have an oil monitoring system that prevents the engine running if the oil isn't all the way up to the bottom of the threads in the oil fill hole.
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
383 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
