Question about Toshiba 65HX81 65" Rear Projection Television
Power light blinks and no picture
Power light blinks and thats it... its a 7 year old tv first time it broke
is it worth fixing.. as i hear if its the power supply is a 500.00 repair but the convergince board will also go shortly?? what do you guys think thanks
  • 4,402 Answers
Sounds like loose connections on the convergance amps ic's
Posted on Dec 25, 2007
Projection tv is about 7 years old. I am getting no picture. when I turn it on the red light just blinks and no picture no sound. the tv just will not power up. I unplugged to reboot. did not work. Is...
If this is a Sony Grand Wega, call Sony, complain, and Sony will give you an option to get a brand new for a very small amount of money instead of fixing the one you have due a class action, if you qualify.
Apr 13, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
While watching tv on saturday, my screen went black and their is absolutely no picture nor sound can you tell me if i can fix it as it is only 3 years old
Any indication of power? red light? blinking light? Sounds like the power supply failed if no indicators on. 3 yrs is an average lifespan for these new sets.... unless you are a tech, it's time for a repair shop. Get an estimate first, sometimes its not worth getting an old set fixed...
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
TV shuts itself light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
TV Turns self off- 4 blinks on standby light
Yes, the blinks are error codes. I would not bother trying to figure out what they mean, I can tell you right now. Expensive repair. Average repair costs are 1/4 to 1/2 of the TV's current worth. Most likely a bad transistor. The average expected life span of a TV set is 3-5 years. After that, stuff starts wearing out fast. Time to move on.
Nov 14, 2008 | Sony KV-28FX60 28" TV
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KV-36hs500 problem
The 7 blinks indicate a high voltage shutdown condition. This means that the high voltage has exceded 33,000 volts. This is usually due to a power regulator problem. The regulator in this set is probably an STRSxx (I don't have a listing for your model) and shouldn't cost more than about $25 or so. If the picture was good prior to the failure and you can replace the part for less than $150 or so, it is probably worth it.
Jul 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is is worth getting repaired?
Power supply mnay be out. Yes, get an essimate if you like first, but if it's less than 8 years old-get it fixed.
May 05, 2008 | Sony KV-32FX60 TV
Sony Wega wont go on
When the " SONY Bliking Codes " generated the circuits self diagnostic to trigger the pulse because some error accure....5 times blinking mean there's something wrong whit RGB level,the level not balance after 2 second due at first time the tv on...the protection circuit will send the error report,the tv will have no picture or will need to check at M board there's much things you have to do...
Mar 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Toshiba 65HX81 65" Rear Projection Television Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
