Question about Kenmore Elite HE4 Electric Dryer
Power is on but when i go to start it will not
Power is on but when I select my time and press start it will not start. It makes a beep and a click and then nothing happens.
My dryer is turning on but it does not work. what should I do?
Posted on Sep 23, 2009
I cleaned all the information off my c55d-p-pscmyu toshiba satellite. How do i recover back to fac tory
Warning: All data on the hard drive will be erased. Back up any important data before proceeding. Make sure the computer is connected to a power supply and do not switch it off or restart during the process. •1) Hold down the power button for ten seconds to switch off your machine •Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
•2) Press and hold the zero key and at the same time, tap the power button once to switch on your notebook
•3) When the machine starts beeping, release the zero key
•4) When prompted by the warning screen, select Yes to continue with the system recovery
•5) Select Recovery of Factory Default Software and click Next
•6) Select Recover to out-of-box state and Click Next again
•7) Click Next to Start the recovery
May 10, 2017 | Toshiba Computers & Internet
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Recovery disc windows vista
    you can restore completely by doing a factory restore. you will lose all your data, however, so you should backup your important data. i found these steps
    \1) Hold down the power button for 10 seconds to switch off your machine. 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. 3) When the machine Starts beeping; release the 0 key. 4) When prompted by the warning screen; select Yes to continue with the system recovery. 5) Select Recovery of Factory Default Software; click Next. 6) Select Recover to out-of-box state. Click Next again. 7) Click Next to Start recovery.
    Jan 28, 2014 | Acer Aspire 4520-5582 Notebook
    I want to restore my factory settings on my toshiba satellite
    If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
    1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
    your notebook.
    2. When the machine Starts beeping; release the 0 key.
    3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
    4. Select Recovery of Factory Default Software; click Next.
    5. Select Recover to out-of-box state. 6. Click Next again.
    7. Click Next to Start recovery.
    8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
    Apr 06, 2012 | Toshiba Satellite Computers & Internet
    How to make a full destructive recovery on a tecra s4
    your notebook.
    Mar 19, 2012 | Toshiba Fusion Satellite U405-S2833...
    How to go back to factory settings
    All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
    -Shut the computer down completely
    -hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
    -when the computer starts beeping release the 0 key
    -when the prompt comes up choose YES to continue with system recovery
    -Select recover of factory default software and click NEXT
    -Click Next again to start recovery
    Hope this helps!
    Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
    How to mater reset
    1) Hold down the power button for 10 (ten) seconds to switch off your machine.
    Mar 04, 2011 | Toshiba Satellite Pro L300 Notebook
    I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
    Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
    Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
    How i reset my laptop without the disk
    5) Select Recovery of Factory Default Software; click "Next."
    6) Select Recover to out-of-box state. Click "Next" again.
    7) Click "Next" to Start recovery.
    Hope this helps!
    Sep 07, 2010 | Toshiba Satellite A215-S4747 Notebook
    11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard...
    In order to solve the problem this is what I did (with a help of Mr. Hilik
    @ www.microgal.co.il)
    1. Unplug the power cable 220Vac from the wall outlet.
    2. Make sure or the clock led is "off" and screen is dark
    3. Plug again the power cable 220Vac
    4. Nothing comes "on" on the led screen
    5. press on the digit "zero" (0) and you hear a beep signal
    6. Take a glass filled with water press on the digits "1" and then "0" and
    then "start"
    7. After 10 seconds the beep signal will come on again.
    8. Note: this kind a phenomena appears after voltage cut off when there
    is a need to lift up again the handle on the voltage breakers . FYI.
    Jan 30, 2010 | Microwave Ovens
    Kenmore Elite HE4 Electric Dryer Logo
    105 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
