Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Will not start at all
I've had my vacuum cleaner for about four years and it worked great. All of the sudden it won't turn on - nothing. I changed the bag, but still nothing. Any suggestions?
  • boycrazee Jan 15, 2008
    exactly! mine wont start either. was working fine this morning!
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Most likely if it dont turn on at all period.1 of 2 things on/off switch went out or 2 motor burned up but most time u can tell if it is bad motor cause if it smelt like burnt plastic ever bad news its dead but hopefully u can just change switch
Posted on Jan 06, 2008
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Dyson vacuum cleaner was working ok but now is dead. nothing. I have changed the fuse for one I know is working.
Sorry to hear you're having difficulties with your Dyson vacuum. If the cleaner won't start at all, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 18, 2011 | Dyson Vacuums
The vacuum won't start. I used it for about an hour and then turned it off and when I went to turn it back on ..there was no response. I cleaned every compartment on the machine and it's still not...
Sorry to hear you're having difficulties with you're DC07. If the cleaner won't run at all, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in touch with you as soon as possible. We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 11, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
My electrolux oxygen vacuum cleaner shut off and will not turn back on. It's less than a year old, but I bought it off Craig's list--they were the orginal owner and they said they bought it in May of 2008....
No..Electrolux is really great about warranty service. They will help you even though you are not the original owner. http://smallappliances.electroluxusa.com/files/usa_english/0-999/OxygenOwnersManual.pdf owners manual. Here is a link to the site.
http://smallappliances.electroluxusa.com/node82.asp Also, you might check for an obstruction. The Electrrolux is thermostatically protected. Means that if there is no airflow through the motor, the motor will shut down before overheating can occur. Remove your hose from the cleaner. Drop a quarter down through it, did it come through? If not, you have a clogged hose. If it came through, remove your wand from the power nozzle, look througfh the wand, is it clogged? Now, look at the power nozzle, can you see light through the elbow? Your cleaner will come back on after it has cooled. Try the machine. It should be working now. I hope I could help to Fixya! Please let me know if I helped you. Thanks, Rene (the Vacuum Doctor)
Nov 15, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kenmore 33721 does not start
Same thing happened to me. After taking the cover off I noticed a wiring diagram on the inside cover. There is a fuse between the on/off button and the motor, sure enough the fuse had blown. There is no mention of a fuse in the manual! The vacuum works great again.
Apr 23, 2007 | Kenmore 33721 Upright Vacuum
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
215 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
