Question about Canon PIXMA MP830 All-In-One InkJet Printer
Ink line on back of paper - Canon PIXMA MP830 All-In-One InkJet Printer
Big black vertical line on the back of the paper. Have cleaned the nozzle several times as directed by online instructions, but still ink line tehre, you say clean the nozzle with a stick, but you dont say...
Any ink on back of paper is a stain and not a print. So open the cover and look carefully and well into the printer, the path of the paper, and you will most likely see ink stain about the area where the stain occurs and wipe thoroughly with tissue a soft cloth.
Good luck 7 God bless!
Mar 03, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
When printing a document on printer it prints a line and then a solid black line beneath that.
Sounds like a bad ink cartridge. The ink is probably clogged up in the print head where the ink comes out of the cartridge. You should either bring it back to where you purchased it for a replacement, or you can try priming the ink.
To prime the ink:
1. Get a wet paper towel
2. Get a dry paper towel
3. Take the bad ink out of your printer
4. Move the ink back and forth from the wet towel to the dry towel touching the print head (part on cartridge where the ink comes out) to the towel.
5. You should begin to see the ink come out in a higher consistency
This will help unclog any ink stuck in the pores of the print head. If that doesn't work, you may need to get a replacement from where you purchased it.
Hope this helps :)
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
Solid black ink line on the back of any page copied, so heavy it bleeds through the paper
Hello. When you get ink on the back side of the paper that indicates that the printer roller [or platen] is dirty. To clean it get some paper towels and some rubbing alcohol. then, dampen a paper towel and start cleaning the roller. Carefully work your way from one end to the other and then all the way around the entire roller.
Dec 01, 2009 | Ovens
Cannon Pixma MP500- I get a solid black line on the reverse side of a printed page. Went through all the cleaning procedures and new cartridge, no change.
For some reason, the printer is designed to dump ink into the bottom of the tray before feeding on the paper. The paper is then dragged over the ink, leaving the black line. This is a software issue, not a hardware one. I'd advise that you update all of your print drivers, as well as your firmware.
A temporary fix is to clean the rollers and base plate of the printer for ink spills.
Check for any bits of paper or debris that may be caught in the printer. Be careful to feed in the paper perfectly straight, as this printer does not have good rollers, and it will cause paper to break off and cause problems. If any debris has caught or absorbed ink, it will cause the back of the paper to smudge, and you have black lines.
Jun 23, 2009 | Canon Office Equipment & Supplies
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Epson 7600pro air in ink line
You can try an Initial Fill of your ink carts. It is the next level after attempting to clean the heads. However, if this only temporarily fixes your problem, you could have a leak in the supply tubes, or the head could have failed.
Turn the epson off. Hold down the buttons [Paper Feed δ]+[Paper Feed ∇]+[Cut/Eject] and turn on the printer. This will take you into a hidden service menu. Hit the [Paper Feed ∇] button until you get to "Cleaning" then hit the [Select] button to enter that submenu. Hit the [Paper Feed ∇] again until you see "Init Fill", and then hit the [enter] button. The display will say "charging". Just wait until it is done, then turn the printer off and back on.
If you do not have enough ink in the in the carts you will be prompted to replace them. The same goes for the maintenance tank. Make sure you put the ink lever back in the lock position if you change the carts. (It will not give you an error about the ink lever being down, it just won't do anything.)
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
Black ink
I called the local Canon printer repair facility, and a serviceman said that the black line is caused by too much ink in the ink absorber device below the paper path. He said to fix it requires disassembling part of the printer, replacing the absorber foam, installing a longer tip for the excess ink, and reassembling and testing the printer. I asked if this would be a permanent fix. He said no, that the problem could reoccur as the absorber foam would eventually fill up again.
Aug 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
I have a black line of ink on the back side of the paper when I print anything. It fade through to the front. The line goes down the middle of the paper and is about 1/4 in wide
Cause: Possibly a leak in an ink cartridge. Pull all of your cartridges and inspect for leaks....it will be obvious and you will probably get it all over everywhere if you are not carefull, so be prepared to immediately toss it in the waste bin.
Solution: Sounds like you have ink (wet?) inside the paper path on one of the rubber rollers. It sounds like it is so saturated with ink that this will continue for a long time until it either runs out or you replace the roller.
Look for the roller that is where this line appears. Using another piece of paper or a paper towel soaked with alcohol (rubbing), touch it and see if ink doesn't appear on the paper. If it does then you might be able to clean it by continuing to soak up the ink on scrap paper by pressing it out of the roller. It won't completely fix the problem and it won't do it right away but it will get it started.
Jun 21, 2008 | Office Equipment & Supplies
I have a Canon PIXMA MP830 Office All-In-One Printer. when I print there is a 1/4 inch ink line on the back of the paper. I clean the bottom plate and it goes away but if the printer sits for a while and I...
Your cartriage is leaking ink, thats why it comes like.
Replace your cartraige immediatly if you are using a refill, it might not be refilled correctly.
Put the original one it will fix your problem.
Thanks
Iqbal
Mar 29, 2008 | Computers & Internet
Canon PIXMA MP830 All-In-One InkJet Printer Logo
18 people viewed this question
old marine
old marine
