Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Outdoor unit cutting off after 10 minutes error
Outdoor unit cutting off after 10 minutes error code p8-00 any suggestions
5 Suggested Answers
relaga58
  • 158 Answers
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Posted on Jun 01, 2009
SOURCE: amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Posted on Jul 13, 2009
SOURCE: Mitsubishi Mr slim Airconditioner error check P8
I Have same problem
Posted on Sep 28, 2009
heatman101
  • 43501 Answers
SOURCE: outdoor unit stops and starts every 5 to 10
The most common cause for the unit to cycle like that would be a low charge situation.
If you are low on freon the unit will cutout on low pressure and then when off the pressure will go back up and the cycle starts all over agian.....
Get a certified professional to check the unit out and fix the leak so that once recharged the unit will hold the freon.
The most common place for them to leak is the piping connection behind the indoor unit...although it could be the connection at the outdoor unit also...
These are flare connections and they can and do loosen up over time from the vibration...
heatman101
Posted on Mar 24, 2011
Hi. i have a 36000 BTU Pridiom unit # POM365HX that is showing a P4 error code i was wondering if a service manual , troubleshooting guide was available for this unit.
P4 looks like a conpressor error on the outdoor unit. Possibly a voltage spike, pull the disconnect at the out door unit for 10 seconds and reinsert hopefully error clears. If not you will need to open outdoor unit and get error off of outdoor pcb
Jul 05, 2017 | Heating & Cooling
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
I have a fujitsu air con which is flashing 3 times on the timer. It runs for 10 seconds and then shuts down and then flashes 3 times. Model is a AOTR09LCC
Serial signal (reverse) error, during operation.
Try turning power off at isolator for ten minutes and then switch back on. If error code persists, you will probably need a new controller PCB in the outdoor unit.
When the indoor unit does not receive the signal for 10 consecutive seconds during the operation >Permanent stop after 30 seconds.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor
unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
Feb 19, 2015 | Fujitsu Heating & Cooling
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
Eo error code indoor unit runs 2-3 seconds then gives eo error code problem started when mr chipmunk chewed mr slims 12 volt wire connecting to out door unit and shorted it . Outdoor unit has bad control...
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Jul 20, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
CH 5
This is a Comms error, you may have had a power spike/voltage drop/power cut. Or a wire has been broken but this is unlikely.
I would suggest turning the power off at the indoor unit by the isolator, and also the power at the outdoor unit. leave off for 10 minutes, turn on isolator on the outdoor unit and then the indoor unit. Then start the unit up.
If the problem persists you may have a fault with the unit and a A/C contractor would be required.
This is a common call for LG equipment, i get it all the time.
all the best
Jul 05, 2010 | LG Art Cool LA121CNP wall/window Air...
ERROR CODE CH5 AIRCON SPLIT LG
This error is a communication error between your indoor and outdoor unit. You can try turning the breaker off for a few minutes and restart the unit. However if that does not work its best suggested to have an authorized HVAC technician service the unit.
Dec 24, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Turn on and off the unit
-Check the setting of your temperature.
-Check if the timer is not set.
-Check if no restriction in your outdoor or indoor and outdoor are both clean.
-Check if no error code (flashing light) at the indoor.
Jan 07, 2008 | Sunbeam SCA103RWB1 Room Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
95 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
