I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. I WOULD LIKE TO KNOW WHAT CHANNEL MY TV SHOULD BE ON?
  • constantrdy Sep 23, 2009
    THE CONNECTION SEQUENCE OFFERED BY JVC:
    TV ANTENNA TO SET TOP BOX TO DVD TO TV. i do not receive a picture on channel 3 or 4. i am using the audio and video cables supplied by jvc.
  • 11,896 Answers
If you are watching AIR (regular tv) It can be on any channel you wish.
If you are using a dvd player then you will want to change the channel to AV or INPUT
If you are using cable/dish box or vcr with coaxil cable, then you will want channel 3 or 4
If you are using cable/dish box or vcr with RCA jacks, then you will want the AV or INPUT channel. Some tv's have AV 1,2,3 also. Depends on what number your device is hooked up to.
If you have all connections correct and never get any type of picture what so ever, then you may have a bad tuner chip/board
Posted on Sep 23, 2009
    Brigadier General:
  • 4,044 Answers
Ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
  • James Young Sep 23, 2009
    You will need to make sure is set to use the same channel. There are usually switches on the back of the devices to make this selection except for the TV. The problem with setting this up is that most the DVD players today come with audio.Visual cables or S-Video cables or HDTV cables but not Antennea cable connections. This forces you to connect to secondary input on the TV instead of connecting everything in a loop: Satelite->DVD->TV.
HOW DO I GET MY DVD OFF PROGRESSIVE SCAN
You do either of the following; refer to your instruction manual (if you still have it) and look for general output settings to turn off progressive scan, or you can try something much simpler.
On the front of the unit, without a disc inserted, and the drive selected as DVD, press and hold STOP button for 10 seconds (on the unit, not the remote), then release. This may revert progressive scan back to normal interlace for your TV, and thus turn progressive off.
This trick works for Goldstar, Samsung, some LG, Magnavox, and Zenith DVD players. Give it a try before referring to the manual.
Apr 13, 2011 | JVC DR-MV150B DVD Recorder/VCR
I lost my JVC remote control model DR-MV79B, This is a some kind of combo DVD/VCR. I tried a rca universal but didi'work
Each universal remote have certain code for each TV, read the manual for code, match the code with your JVC.
Feb 10, 2011 | JVC DR-MV79B DVD Recorder/VCR
I have a jvc dr-mv150bj. I am knew to recording on DVD. I used the dvd to record the super bowl. I forgot to finalize and I was using a portable LCD projector. I unpluged the dvd recorder and took it...
finalizing completes the process of recording so that the disk can be read to play. Yes, probably if power goes off, you'll loose the recording as the disk can finish.
Basically, the code written at the end of recording creates a sort of index so the player knows how to read it.
May 02, 2017 | JVC DR-MV150B DVD Recorder/VCR
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
I bought a new JVC dvd recorder vcr combo model#dr-mv79b. I lost the manual and need another one. When can I get another one?
DR-MV79BC:
http://books.jvc.com/booklist.asp?Model=DR-MV79BC
DR-MV79BJ:
http://books.jvc.com/booklist.asp?Model=DR-MV79BJ
Mar 14, 2010 | JVC DR-MV78B DVD Recorder
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Recording digital channels
Connect your set top box to Scart L2 (the Right hand one).
Select Prog 1. Then Channel down until you get to L2.
This should work.
Jul 12, 2008 | JVC DRM10 DVD Recorder
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
