WHAT KIND OF MOWER (BRAND) WHAT MODEL NUMBER WHAT SERIAL NUMBER WHAT ENGINE INCLUDING NUMBERS OFF IT WHAT "SHEARED PIN" ARE YOU TALKING ABOUTWHAT KIND OF MOWER (BRAND) WHAT MODEL NUMBER WHAT SERIAL NUMBER WHAT ENGINE INCLUDING NUMBERS OFF IT WHAT "SHEARED PIN" ARE YOU TALKING ABOUT
Check Belts as well as the shear pins in your pulleys .if the pulley turns but does not drive I suspect a shear pin has sheared off and needs replacing. The shear pin is inside the pulley and you need to remove the pulley to get to the pin.
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
I would assume the mower deck was engaged, check the shear half moon key in the shaft and flywheel. they are made to shear to prevent engine damage. other than that, check all the safty switches that keep the mower from starting unless they are engaged.
Go to www.partstree.com Take and put in the model number off the tractor and look at the diagram for the drive train or transaxle . Look to see if there is a Shear pin that may have sheared ? Or some lawn mower have 2 belts , one for reverse and one for forward . Contact me with you model Number off the tractor and the motor ; I can see if I can help find the fix for it . I work on small engines and without having a little more information . I can give you an idea to try , but with the numbers I can do more research and hopefully find the fix .
Sounds like you may have hit a rock or log which shears the pin on the crankshaft to save the engine. It's a simple job to check the crank shear pin and see if it sheared and its a simple job to replace it. Youtube videos should show the process.
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
SOME SELF PROPELLED MOWERS HAVE A SHEAR PIN IN THE DRIVE BOX THAT MAY HAVE SHEARED . IF THE MOWER GETS A LOT OF USE THIS PIN CAN SHEAR. ALSO SOME HAVE A FRICTION DISC, LIKE A CLUTCH THAT MAY BE SLIPPING. CHECK THESE TWO THINGS CAN'T TELL MUCH MORE WITHOUT A MAKE AND MODEL
It sounds like your timing's off. Take the sheetmetal cowl off and remove the flywheel on top. Check your shear pin and replace if necessary. It sounds like there is some offset there. The shear pin should get you back running right. Best regards, --W/D-- please feel free to rate this solution! Thanx!
if that is the part to move back and forward.
the sheared pin that makes the mower move
are you talking about the flywheel shear pin
